Front Caliper Problem
SteveR
Post by SteveR » Sat Jun 20, 2009 1:16 pm
Just trying to remove the calipers to change front discs on teh TT and found the sliding pins had seized. In trying to loosen one of them it sheared off so now I need a new caliper for front LH. The caliper shows as Girling but on ebay calipers are advertised for the 480 as ATE and one place asked me if they were Lucas. Does anyone know what the differences are and if they are interchangable?
Steve Robson
At Nurburgring (pic Suddy)
No longer a 480 owner :-(
ted clutch
Post by ted clutch » Sat Jun 20, 2009 5:28 pm
i think the difference is vented or not.on the solid disc the pins are seperate.you wouldnt need new caliper .they are just a slide fit.
SteveR
Post by SteveR » Sat Jun 20, 2009 7:54 pm
I suspect that ABS is ATE and Non ABS is Girling as the caliper says Volvo Girling on it.
I agree I do not need a complete assembly including piston and all but it seems that is teh only way to buy - all I really need is the solid frame bit with the sliding pin assembly.
Steve Robson
ted clutch
Post by ted clutch » Sun Jun 21, 2009 10:37 am
its called the carrier.some places will carry that separately.maybe the stealer.may be worth a try. colud try breakers. if you drill down the bolt where the head was with a bit slightly smaller than the bolt it will come off.mine is girling solid no abs. some 440 are the same.i see if i find one.
SteveR
Post by SteveR » Sun Jun 21, 2009 11:33 am
Thank you for the thoughts ted clutch. I considered drilling down but would rather get a new/used carrier as I suspect the whole inside of the slider housing is rusted beyond reuse. At least I can use the GT for some contract work I have this week. If you have a carrier lying around with good sliders I would be pleased to buy. gingerheed is also checking a subframe he has.
Steve Robson
SteveR
Post by SteveR » Mon Aug 24, 2009 3:06 pm
As someone is going to buy the GT (saving it from the scrappage scheme) I need to get the TT on the road and phoned Volvo. Apparently there is a repair kit for teh rusted pin for just over £20 so as Ted says I will drill down teh carrier and fit the pin - news when it's done - before we move house in 28 days ish from far SW Hampshire to far SE Dorset where they are building a reef to improve the surfing.
Steve Robson
rgreenhalf
Post by rgreenhalf » Sat Aug 29, 2009 10:28 pm
Have you tried brakeparts.co.uk give them a call they might be able to help.
1990 Volvo 480 Turbo - Sold
1994 Volvo 480 Turbo - Sold
1990 Volvo 480 ES - Broken
SteveR
Post by SteveR » Mon Aug 31, 2009 9:27 pm
Had a look at the website but it does not look like they have the bits I need which are often the car manufacturer's items but I will give them a call if the Volvo bits are not ok. Many thanks.
Steve Robson
rgreenhalf
Post by rgreenhalf » Mon Aug 31, 2009 9:38 pm
Yeah give them a call, often they'll do you a decent postage price too if its only a little item :D
Post by glasgowjim » Mon Aug 31, 2009 9:46 pm
SteveR the sliding pins you are looking for are they steel/silver coloured about 5/6cm long round and smooth with a narrower thread about 8mm at one end. if so I am certain to have spares of these.
Just checked if it it these you need then look no further as I have abouty 8 spare of these
Image :D
SteveR
Post by SteveR » Mon Aug 31, 2009 10:32 pm
This is the item:
It's item 9
Steve Robson
Post by glasgowjim » Mon Aug 31, 2009 10:33 pm
Steve cant see the photo!
SteveR
Post by SteveR » Mon Aug 31, 2009 10:34 pm
Yeh - I forgot I rejigged my web site - working on it...
Steve Robson
Post by glasgowjim » Mon Aug 31, 2009 10:43 pm
Would need to check my shed tomorrow in daylight.
SteveR
Post by SteveR » Mon Aug 31, 2009 10:46 pm
Gracias - I may also need item 8 which is the large carrier to the right of the pic - number not quite on pic.
BTW its an L reg
Steve Robson
ted clutch
Post by ted clutch » Tue Sep 01, 2009 10:39 am
thats a rear caliper slider jim has in his hand.
SteveR
Post by SteveR » Wed Sep 02, 2009 10:40 am
The repair kit from Volvo arrived today price £22 + vat.
Next job is to get the rusted pin out - don't hold your breath cos I'm in the middle of house move and stuff.
Steve Robson
SteveR
Post by SteveR » Sat Sep 05, 2009 7:51 am
Work in progress to remove the sheared off pin. It must be well rust welded in because I have tried copious amounts of release agent along with gentle heat (ie my faithful ronson gas flame) so I hope another day of persuading will work. Next stage is to remove the carrier - grip the pin in the vice and turn the carrier - appliance of science.
close up of sheared pin
general shot
Steve Robson
ted clutch
Post by ted clutch » Mon Sep 07, 2009 12:35 pm
thats proper stuck.never seen one that bad.could it wreck the carrier when its pulled out.
SteveR
Post by SteveR » Mon Sep 07, 2009 2:07 pm
Yes - quite possibly - my thinking now is to drill out.
Steve Robson
