ABS Problem
Amonra
ABS Problem
Post by Amonra » Sat Apr 28, 2007 9:47 am
All of a sudden my ABS is acting up.
Whein i put in the key and turn it half way the abs light in the dash goes on and turns off after a few seconds indicating it is ok.
when i then turn on the engine it turns on again and off again after a few seconds.
when i then start moving it turns on again and does not turn off.
i slap on the brakes to test if the abs is still working but it is not.
what is wrong ?
i read somewhere that it could be from some sensors, but where are the sensors located and how do i clean them ?
Brasco
Post by Brasco » Sat Apr 28, 2007 3:07 pm
Is this the old type ABS? If so, check the connection to your ECU and that it is secure.
(near-side cubby hole in boot)
Amonra
Post by Amonra » Sat Apr 28, 2007 4:54 pm
i guess it is the old model as the ABS computer is in the luggage boot inside a small compartment on the left, but i removed the plug and put it back and it's still the same.
robkendall
Location: 2nd star on the left and straight on til morning
Post by robkendall » Sat Apr 28, 2007 5:04 pm
might be a simple statement, but check that the earth 'pin' in the engine bay isnt loose and touching metal...on and off like....turning the abs on and off.
like i said, simple statement, but it could be.
rgrds
rob
VanDerGraaf
Post by VanDerGraaf » Sat Apr 28, 2007 8:42 pm
I've heard of this thing before but I have no idea what it looks like.
Anyone got a pic?
Amonra
Post by Amonra » Mon Apr 30, 2007 7:02 am
It is now going on anf off whilst driving. accelerating/slowing down and bumps seem to be triggering it, so im guessing that it's a loose contact of some sort but i dont know where to look apart from the ABS computer scart.
Amonra
Post by Amonra » Mon Apr 30, 2007 7:21 am
does the ABS system take some kind of fluid apart from the normal brake luiid ? if so what kind of fluid ? and where ?
Amonra
Post by Amonra » Wed May 02, 2007 7:38 am
no one knows where i can find the sensors ?
robkendall
Post by robkendall » Wed May 02, 2007 8:31 am
in the engine bay, by the right hand side (looking from the front of the car) theres the box for the diagnostics? somewhere around that theres a little black plastic pin about an inch long? with a metal tip....if you touch the tip to the body it will cycle the abs on/off....i only had it on the silver turbo, and i didnt have that long, so cant exactly remember where....one of the otehrs will though im sure?
anyone?
rgrds
rob
Amonra
Post by Amonra » Wed May 02, 2007 5:47 pm
the thing is that i want my abs on. i read somewhere that there are sensors in each wheel connected to the abs computer, so i was thinking that either one of them is busted or they are dirty and need cleaning ? but i just dont know where these sensors are exactly.
martinholmesuk
Post by martinholmesuk » Wed May 02, 2007 7:31 pm
end of drive sharfts
there are black sensors and remove wheel and have a look
maybe the ring is dirty which it reads
Audi TT
catgroom
Post by catgroom » Wed May 02, 2007 9:09 pm
The sensors are easy to find at the end of their wires.
You can clean the driveshaft rings with a wire brush.
To clean sensors you dont have to unscrew them.I find spraying them with brake cleaner or any alcohol based liquid is best.
Then,take a cotton bud or a piece of rag and floss them,really!
This should sort out the problem.
I had a 1992 with this problem.It turned out to be that the brake fluid was low.Now,you can fill brake fluid much higher than Max mark on the reservoir.Something I picked up from another forum member.
Good Luck!
Steve
I'm No Longer Here :(
Amonra
Post by Amonra » Tue May 29, 2007 1:36 pm
cleaned the sensors and filled the brake fluid reservoir to the brim. still not working.
i cant find the plastic pin mentioned.
it's becoming dangerous as when im driving the ABS goes on and off occasionally while im braking and when it does that i have no brakes for s second or two.
Is there some kind of diagonistics test i can run for the ABS computer ?
