crap brakes
crap brakes
I've found my brakes a bit on the crap side since I bought the turbo - they're certainly not as good as on my previous ES. So last night I tested my ABS and hey presto its not working.
The light comes on as it should on start-up, then goes out after 30secs or so. On heavy application of the brakes the fluid level and ABS light come on momentarily but go out after a second, no more.
I've checked the level and its fine - put a bit more in after reading a post from mr. catgroom.
Also the brake pedal is very heavy but then I see that there isn't a servo on it anyway (its a '89 car with the ATE system).
Finally theres yet another stray connector in the car, right next to the ABS computer in the boot which is a 3-pin jobby. Is this another 480 'extra' or should it be plugged into anything?
Adam
Adam
- JohnTurbo
The mark three abs doesn't have a vacuum servo like the mark 4 if i remember right...instead it uses hydraulic pressure.
No 480 (and very few lesser cars) can be found without servo assisted braking.
Early fiat pandas, 2cvs, that kinda think will be all thats left.
Past:
94 Turbo - Red
92 Turbo - Red
90 Turbo - Silver
Now:
00 Exige
15 GKD Legend
16 Skoda Superb
94 Turbo - Red
92 Turbo - Red
90 Turbo - Silver
Now:
00 Exige
15 GKD Legend
16 Skoda Superb
- rpruen
Yes the MK3 ABS is a power assisted system, but uses the ABS pump to provide the asisstance. It is more of a power braking system, than a normal setup. It uses a pedal position sensor to provide feedback, notice you can press the pedal to the floor with the ignition switched off... All in all it's a bit of an odd system.
As mentioned above try bleeding the brakes, as air in the system may not be as noticable, due to the way it works. Try pressing the pedal down with the engine running, if the level of fluid drops more than a few mm, then you may well have air in the system.
Richard
Richard
Car Status: Squashed :(
Now have 765 GLE 2.8 V6
- JohnTurbo
If you get really stuck i have an entire mark 3 abs system in my garage that i know works for sure.
By this i mean the abs/pump/linkage from under the bonnet, the braking ECU, and the whole brake wiring harness.
I'd sell it for 30quid.
Past:
94 Turbo - Red
92 Turbo - Red
90 Turbo - Silver
Now:
00 Exige
15 GKD Legend
16 Skoda Superb
94 Turbo - Red
92 Turbo - Red
90 Turbo - Silver
Now:
00 Exige
15 GKD Legend
16 Skoda Superb
- guitarcarfanatic
Had problems with this system on my old car. Definately feels weaker than other systems but you just have to give it a bit more pedal. Just change and then bleed the brake fluid and it should make a difference. Once you get used to the Mk3 system you will find it fine. It actually stops the car very well if you give it welly! It is just getting used to it in the first place that is the tough part.
Previously...
1989 Black ES - Great runner
Previously...
- owen080808
murf told me that bleeding the brakes is actually fine, i had also been put off by the haynes manual "the fluid is at 1000000bar and will cut your hand off etc etc" but i must admit that i haven't quite gotten round to it yet i will one day soon tho, i think as long as you follow all the steps carefully it should be fine...
Currently car-less
| '92 turbo + Rich mod | Sold
- clubman_dan
- 480 Rookie
the old owner of mine was telling me about wehn it had to have a new abs unit fitted a few years ago, the old one just failed for no obvious reason.
it cost £1600 to get a new one fitted (a lot of which was the cost of the part i believe)!!
'95 2.0 es SOLD!
'86 mini 1380 rather fast!!
'95 2.0 es SOLD!
