Oops mixed brake fluids
Post by glasgowjim » Thu Dec 14, 2006 6:32 pm
bled brakes and added dot 4 before I read the post that it was dot 5.1 in the system.
how bad is bad ?
made no difference to brakes there appears to be no servo suction 92 1.7 turboo.
in the wurdz of jar jar binks meesa reetard.
:cryhard:
hjkort
Post by hjkort » Fri Dec 15, 2006 7:04 am
it's not that bad, but the quality is worse than before.
As long as you don't mix it with dot 3 or dot 5 (no longer available, hence the .1 in 5.1)
If you mix dot 3 or 5 than the cups in the system will degrade.
