Hi all
Just Got my 480s MOTed, but now my manual gearbox appears to of lost third gear. Trying to select it, it doesn’t engage, just make a painful gearteeth on gearteeth sound. First and second engage but sometime make dragging, scrapping noise. Forth and fifth are OK. Gearstick linkage seems OK. However driving my sons 460 the gears seem much tighter than my 480. Is this gearbox terminal and is there any one you guys know who could swap the box out in the Worthing, Sussex area. As my local garage think it’s a too bigger job and Hapsteads Volvo, I would have to appply for lottery funding!
The gearbox is a M46 402E from the red label attached to it.
regards
Mark
No Third gear - Dying Gearbox?
- Mark 480s
Not another Volvo!
480 Gone,
940 turbo Imperial Battlecruiser (estate)
940 Turbo Diesel estate
480 Gone,
- Murf
ive never done it myself but apparently theres bushes in the gear linkage and if they go you'll be lucky to get any gear! its worth checking these before you buy a new box.
Either that or the linkage just needs adjusted.
I would get the gearbox oil drained and put it through a strainer and looks for particles of metal in it, this would be a sure sign of a knackered box but it doesnt sound like it to me
Have a look in the yellow pages for a local volvo specialist, like a small independant garage.
Kia Pro'ceed GT 1.6 Turbo
1992 480 Turbo
2007 Focus ST
1992 480 Turbo
2007 Focus ST
- Mark 480s
Hi
I'm going to drain the oil and take the end cover off the gearbox to see if there is anything amiss. There is a thread by Pol on not selecting fifth gear so I hope its along those lines. In Worthing their used to be Anca Volvo, but they close down and Hapsteads took over the volvo franchise. and moved to Hove. This meant all the indie volvo people (esp. one in Lancing - a couple of miles from me, put up their prices!). see what the weekend dicovers.
Mark
Mark
Not another Volvo!
480 Gone,
480 Gone,
mine were very dodgy at the beginning of this week....thought it was going to be a gear box oil change but it was just the clutch cable needed adjusting.....no lockiing nut on the end so it works loose...check your clutch pedal if its sitting lower than your break pedal it could be your prob too.
Volvo 480 Celebration 466 Dark Grey Metallic (PUS)
previously
Volvo 480 2 ltr Paris Blue
Volvo 480 2 ltr Peacock Green
Volvo 480 1.7 White
Volvo 760 GLE Saloon 2.8 V6 Blue
previously
Volvo 480 1.7 White
- Mark 480s
Well heres an update
Drained gearbox oil, it wasn't very clear, infact it was grey! putting a powerful neo magnet on the underside of the plastic oil pan the oil went nearly clear, so I'm afraid the gearbox has ground up some steel. This I suppose means the synromesh is OK (as its made of phoshor-bronze) but the third gear is ground up! no teeth were found mind. Gearbox is coming out and going on the bench this week end.
regards
Mark
regards
Mark
Not another Volvo!
480 Gone,
480 Gone,
