Creaky clutch
dean36014
Creaky clutch
Post by dean36014 » Fri Feb 17, 2006 5:49 pm
Changed the clutch cable on the 480 today, but it hasn't cured my problems.
When the car is cold the clutch is fine, nice and light, no slip. after about 15 minutes of driving the pedal goes "jerky", making pulling away in first a bit intersting. I thought it was the usual seizing up cable, but its not. Further investigation, reveals a creaky noise, when the clutch is depressed, coming from the bellhousing. It only does this when it has warmed up, other than this the clutch works fine, its not heavy, and doesn't slip, no gear selection problems. Anyone got any ideas, could it anything to do with the clutch actuating arm?
Cheers in advance.
Dean
chris1roll
Post by chris1roll » Fri Feb 17, 2006 7:04 pm
Thrust bearing, or maybe just the ball type bit the actuator bears on. squirt some WD40 down there....it'll make the clutch slip for a minute or two, but will soon burn off.
For gods sake don't do anything involving grease or copper slip though!!
haz@nocturnal_development
Post by haz@nocturnal_development » Tue Feb 21, 2006 11:18 am
the bearing, usually with the bonnet up and the engine running you can hear it rattle slightly when the pedal is not pressed, then goes away when it is.
get it sorted when it gets noisier and its deffo the problem.
haz :)
reanualt 5 campus, Volvo turbo conversion, hybrid T28, -31 actautor, external oil cooler, THS intercooler, rear radiator, large throttle, Adaptronic ECU, cossie blue injectors. results recorded '06 (21 psi 228bhp/229lbs),(23psi 12.6 @108mph)
dean36014
Post by dean36014 » Tue Feb 21, 2006 2:21 pm
It's not the bearing, its dead silent with the engine running. it just creaks when you press the clutch :( . I gave it a good dose of wd40 in the bellhousing at the weekend. The clutch seems smoother and lighter now, and hasn't creaked in the last 20 miles.
Post by haz@nocturnal_development » Tue Feb 21, 2006 5:56 pm
ah, could be the cable startin to wear then? might be worth gettin one in the boot just in case, you'll need it one day :) .
haz :)
dean36014
Post by dean36014 » Tue Feb 21, 2006 5:58 pm
Already changed :rofl:
