When I have my foot in a certain position on the accelerator the revs go slightly high for a split second and then the auto box thuds into 4th gear. If I increase the reves it changes fine, its just when I’m cruising that this happens and has only happened a couple of times. Just wandering why it is doing this
Ad
Changing gear, delay (sort of)
- Big Brother
- Moderator
2001 V70
What colour is your ATF Ad?
If its any colour other than pinky red then change it and put Lubegard in with it.You can get that off ebay.
The thud is something I get on mine,not so much now I changed the front gearbox mount though.£90 + VAT
If it has the overhauled box in from memory,get it checked out if you are sure its box related or Stu may help???
Steve.
Steve.
I'm No Longer Here :(
- martinholmesuk
