Transmission finally out
- alfonzobonzo
Finally!! long nose pliers & a good hard tug (oooer) got the speed sensor out
but...... the diaphram springs are covered in a film of black oil.
is this bad?
is this bad?
Alfonz.
Toyota Celica G7 Tsport Storm Blue (LiftTastic)
480 L 1994 2.0 i Metalic Black K&N Panel SOLD (fond memories)
V40 W 2000 1.9 T4 SOLD (kind of miss it)
- Bramdeman
Its ok as long as it doesn't get worse and makes the clutch slip. But since you have the gearbox out it would be smart to fix it now. Take the clutch of the flywheel and then take the flywheel of the engine. Have a look at the crankshaft oilseal Thats problebly where your leak is.
'92 Red ES automatic
'88 340 1,7 Project car
- alfonzobonzo
- Bramdeman
Yeah should be, pull out the old one and carefully hammer in the new onee. Grease it up with motoroil first.
- alfonzobonzo
- rpruen
The seals are not that easy to remove.
Best thing is to screw a self tapping screw into the flat part of the seal, then use a claw bar, or claw hammer to gently pry the seal out. It may take a few goes, but it's less messy than trying to mangle the seal with a screwdriver. IT's also less likely to scratch the part of the crankshaft the seal runs on (that would not do the new seal any good).
Richard
Richard
Car Status: Squashed :(
Now have 765 GLE 2.8 V6
- alfonzobonzo
- alfonzobonzo
hey, i got me box!!
45 notes + found a cheap courier see below, 8.75 + vat next day!!!!
http://www.interparcel.com/courier-quote1.php
hopefully have a go at fitting this weekend
Alfonz.
- Dan the 480 Man
- alfonzobonzo
PLEASE tell me ther arent 2 sizes/pitches of splined drive shaft that fit into the gear box. (off side)
been wrestling with this gearbox all afternoon & have barely got any skin left on my arms, I just cant get the drive shaft to engage.
help
help
Alfonz.
- chris1roll
- alfonzobonzo
- alfonzobonzo
got the box in, in about 3 minutes on saturday, dunno what went wrong the other day, i must have just been being crap,
the shaft doesnt have to be orientated in any way whats so ever, exept obviously you want the holes to line up.
Alfonz.
