Juddering in 1st and reverse!!
guitarcarfanatic
Post by guitarcarfanatic » Sat May 14, 2005 11:47 pm
RIGHT!!! My 480, the thing that by the looks of it is going to make the bank manager hate me has a slight problem. When i go to pull away in 1st or reverse the car judders like hell and it feels like its gonna stall. Even if i give more revs it still trys to stall and judders really bad. Now i immediately figured that my clutch is shagged. I only paid £85 for the car so wasn't too bothered but when i took it for a bit of a spin, it seemed ok. As soon as i had released the clutch fully the car was fine and then it was fine whatever gear it was in. I tried flooring it in second and third(i have never driven such a fast car :D ) and it did not seem to slip at all and ran perfectly until i had to pull away again! Now this made me think it was another problem...I have a very large hole in the exhaust rear silencer at the moment (about 2 inches square as well as maybe another smaller hole i'm not sure about ) which give one hell of a noise (my GF described it as sounding liek a bear). Could this being loose have anything to do with the juddering and shaking very violently when pulling off? Please help me lol!!! Cheers and many thanks to all you lovely (knowledgeble) people who will help my little 480 be restored to her former glory!!!
Previously...
1989 Black ES - Great runner
dragon
Volvo 480 Club Europe CREW
Post by dragon » Sat May 14, 2005 11:52 pm
Sounds to me like your engine mount may be shafted...
Gaz Wilson
guitarcarfanatic
Post by guitarcarfanatic » Sun May 15, 2005 12:06 am
Is that an expensive/easy job to do? I have done it on a renault 5 before...but that was a 1.1 engine and i could lift the engine and gearbox up on my own!!! lol! Any help and advice about how to do this would be much appreciated! Cheers Rob
Previously...
rpruen
Post by rpruen » Sun May 15, 2005 8:29 pm
It depends on the year of the car. If it's an old type engine mount then it's cheap enough, one from a scrappy will be ok.
The newer type oil filled (it's round) mount isn't so good, so there are few if any unbroken ones in the scrappy. They are quite expensive from volvo, and a total pain to do.
Just check the metal bracket as well as those tend to snap as well, if you order a new one, then you get one that has metal twice as think, so that's worth doing if yours is broken.
Post what type of engine mount you have, and I (or someone else) will be able to help more. Also use the search feature, that may turn up some info too :)
Richard
Car Status: Squashed :(
Now have 765 GLE 2.8 V6
guitarcarfanatic
Post by guitarcarfanatic » Sun May 15, 2005 9:13 pm
It's a 1989 f reg so i believe it has the older mounting. How can i check which mounting is broken? Cheers for the advice, Rob
Previously...
Baffler
Post by Baffler » Mon May 16, 2005 2:28 pm
4 poster lift and a tommy bar is you best option otherwise it's down on the flat of your back...
I'm one to talk, I think my rear engine mount is gone too as I have been getting a vibration back through the pedals and steering column/wheel. It's most noticeable @ 15/16/1700 rpms. Also, when I'm cruzing along at an average speed the rear view mirror vibrates and I can't see out of it clearly... I'm scared to ask Volvo for a price :scared:
Liam...
'96 854 TDI SE - D5252T
'98 S40 TD CD - D4192T
'03 S40 1.9D Sport - D4192T3
'88 480 ES, '90 480 Turbo, 91 480 ES...sold :(
Big Brother
Moderator
Post by Big Brother » Mon May 16, 2005 3:00 pm
rpruen wrote:The newer type oil filled (it's round) mount isn't so good, so there are few if any unbroken ones in the scrappy. They are quite expensive from volvo, and a total pain to do.
Richard
:cryhard: That means mine is going to be a right bastard to do :cryhard:
2001 V70
dragon
Post by dragon » Mon May 16, 2005 3:08 pm
Mine is so knackered you wouldn't believe.
But mine is easy to fix, since the engine is already out :)
I'll be taking the opportunity to replace the newer type with the stronger older type when I do it :)
Gaz Wilson
rpruen
Post by rpruen » Mon May 16, 2005 9:17 pm
The older type won't fit on the newer type subframe, just so that no one gets the wrong part thinking that they are interchangable.
If you have the new type then you need to change the subframe to the old type, and also the front left gearbox mounting needs to be changed. Lots of work if the engine isn't already out of the car.
I do have an adapter plate to convert the old type engine mount to fit the new type subframe. Only one exists so I'm open to offers. I will just warn you that it is not easy to fit, in fact you need rubber wrists to do the bolts up.
Richard
dragon
Post by dragon » Tue May 17, 2005 11:36 am
Rich is correct - I neglected to mention that I'm changing subframes too
Gaz Wilson
lee
Post by lee » Wed May 18, 2005 8:16 pm
This is not bad. The rear engine mount is very easy to change as long as you the the tools to do the job.
The bracket for the newer style engine mount is not too expensive, if i remember right it was only £30 inc vat. But the mount is more like £70 + vat
hmmmmmmmmmmmmmmm
chris1roll
Post by chris1roll » Thu May 19, 2005 8:23 am
IIRC when Richard rang up to get prices, you could easily double that then add some. Stupid money. Which is why we made the adapter plate to fit an old type one.
Baffler
Post by Baffler » Sat May 21, 2005 2:23 pm
FYI...
Round type:P/N 3417259 according to Vadis/main dealer. €114 plus vat.
I have the B18EP engine (M57 gbox).
Liam...
rpruen
Post by rpruen » Sat May 21, 2005 7:03 pm
I think the price must have gone down since then! It came as a bit of a shock when I phoned up for a price.
Also as with some of the other parts, prices seem to be different from Volvo dealer to Volvo dealer?
Richard
chris1roll
Post by chris1roll » Sun May 22, 2005 9:18 am
Yeah, seem to, although I thought you rang Taunton Motor co, Formula Cars, and Shipham......
Still, don't need to worry about that particular part any more!
heavend
Juddering clutch
Post by heavend » Fri Jul 20, 2007 10:37 am
Did you get it fixed in the end?
I'm noting alot of people on the net commenting on their clutches juddering when the car was cold (which mine is doing) and getting better once warm.
I blamed the engine mounts - which were OK - before I found that the engine movement damper had come loose. Fixing this helped alot, but the juddering when cold remains.
balto8
Re: Juddering in 1st and reverse!!
Post by balto8 » Sun Feb 22, 2015 12:01 pm
I know it's an old post but I'd like to share some information.
I've been fitting a new clutch in my 1991 turbo and while dismounting the gearbox we saw the rear gearbox rubber support was broken and replaced it. Most of the dashboard vibration on 1st and 2nd gear are gone.
1991 480 Black Turbo
2012 Seat Exeo ST
2013 VW Polo TSI DSG
