AWD conversion
robkendall
AWD conversion
Post by robkendall » Mon Mar 07, 2005 3:06 am
for all you techies again......
thinking about maybe doing an AWD conversion......
looking at maybe fitting the MTX75 transverse box...would have to modify it to fit of course, and then replace the back axle with something.
are there any easier ways of doing this...ie are any of the other AWD volvos transverse mounted?
has anyone ever heard of gearboxes with a PTO output on the back, to drive the rear axle? (personally i wouldnt, but ive heard rumours!!)
how hard could it be???
rgrds
rob
Post by pol » Mon Mar 07, 2005 8:29 am
Probably not the easiest job ever!
Big Brother
Moderator
Post by Big Brother » Mon Mar 07, 2005 9:22 am
You looking for some punishment Rob? :D
Ad
2001 V70
martinholmesuk
Post by martinholmesuk » Mon Mar 07, 2005 9:26 am
Hi Rob,
If your going make AWD 480 then (IMHO) use a turbo engine with the rich mod as it can be hard to put all the power down.
martin
480_rocket
Post by 480_rocket » Mon Mar 07, 2005 10:41 am
Maybe you can get some bits from a 360/340 to fit, prop shaft, rear axle etc. Fari amount fo work, but would be well worth it and I reckon it can be done. I'd say you need it with the power you can get out of the turbo lump with richards mod.
bbf
Post by bbf » Mon Mar 07, 2005 4:03 pm
i think 300 rear axles would be as usefull as original, coz they don't have differential in it. and they have leaf springs. better use a dana sort of axle..
'86 480 ES, RIP :(
'91 480 Turbo, RIP :(
'93 480 2.0, RIP :(
480_rocket
Post by 480_rocket » Mon Mar 07, 2005 4:14 pm
no diff?! surely they had something to distribute power properly?
vins480t
Location: Nw & St. Jland. . . Drives: a 960 . . . . On my mind: Baby in the car!
Post by vins480t » Mon Mar 07, 2005 5:24 pm
i think a 700 rear axel will do the trick better.
but the problem is how to get the shaft there
there is no room for a shaft underneath the 480
what to do with the tank
or how to get the shifting working
and where to put the exhaust
usefull item cud be a alfa 33 4x4 gearbox
thats a original frontwheel drive but wit an add-on its 4x4
chris1roll
Post by chris1roll » Mon Mar 07, 2005 6:08 pm
Yeah, where were you planning on putting the prop, etc?
Unless your going to make the Handbrake tunnel absolutely Hoooge like the 340.....
Ettore Bugatti
Post by Ettore Bugatti » Mon Mar 07, 2005 6:11 pm
hmmm,
What about a second engine?
Perhaps a awd from Renault Kangoo 4wd will work or perhaps the 4wd system of a Peugeot 405 or Citroen BX will fit.
You dont want a live axle though. An de Dion axle would be nice.
Or buy an Impreza :shock:
Rover Mini 1000, june 2009-
Daniel480
Post by Daniel480 » Mon Mar 07, 2005 6:25 pm
BMW E30 IX
rpruen
Post by rpruen » Mon Mar 07, 2005 11:45 pm
I too would like AWD... driving about today I could accelerate faster if I didn't end up wheelspining in third.
The PTO from the box is easy enough, costly... but not so hard. Get a bearing housing made and cut a hole in the side of the dif housing, then a gear made to take power from the dif.
A Honda CRV dif will fit at the rear of the car without removing anything, as it's turned through 90 degrees compared to most (so it's very shallow). You would need to make the front gear to match the rpm to the ratio, and give the drive distribution requred.
Prop shaft..... God only knows where it can go :(
Richard
Car Status: Squashed :(
Now have 765 GLE 2.8 V6
bbf
Post by bbf » Tue Mar 08, 2005 10:20 am
gear rpm matching wouldn't be enough, what you have to do is drive rear axle through slippery clutch (haldex) or make a central diff.
'86 480 ES, RIP :(
'93 480 2.0, RIP :(
rpruen
Post by rpruen » Tue Mar 08, 2005 9:37 pm
I agree with you there. I'd just not mentioned that some sort of clutch would be required. A center dif for the 480 gearbox would be hard to do because there isn't enough space.
Richard
robkendall
Post by robkendall » Wed Mar 09, 2005 10:47 am
MTX gear box is what is used on a lot of rally cars as far as im aware....quaife do em cheap enough....they even do a seperate bell housing to matc any engine, so matching the box to block isnt hard (costly, but not hard)
its a transverse box, with a seperate ratio matched output for the rear wheels, giving something like 64:36 ratio back:front (just from memory...not sure if exact)
am very dubious about going the PTO route....i though they spun at a specific rpm? if so, would, as been stated need some kind of gearbox type thing in between pto/rear axle? (4wd transfer box?)
prop shaft isnt hard either....company near me will make a full prop, carbon composite, so light, for about 50 quid...again, can have it to match any plate either end.
run the prop straight up the hand brake tunnel...maybe need abit of welding doing there...not hard...cut a tunnel out of some other rwd car an weld in....hand brake cable could be routed anywhere really...maybe put it as a 'pull' on the dash somewhere? (under steering column?)
petrol tank...lift into the boot....boot aint much use....never carry the space saver wheel...could lift the floor high enough to put the tank in there...isnt i a GRP tank anyway?? have another one fab'ed to fit where ever.
i really like the idea of awd...i think the car deserves it....especially if mr pruen is giving the engine so much welly!
(ps martin....am looking at a turbo this weekend ;) )
rgrds
rob
martinholmesuk
Post by martinholmesuk » Wed Mar 09, 2005 11:30 am
(ps martin....am looking at a turbo this weekend :wink:
Good man :-)
dragon
Volvo 480 Club Europe CREW
Post by dragon » Wed Mar 09, 2005 12:14 pm
Yeah, mine! :P
Gaz Wilson
martinholmesuk
Post by martinholmesuk » Wed Mar 09, 2005 12:29 pm
Really?
robkendall
Post by robkendall » Wed Mar 09, 2005 1:00 pm
if you wanna sell yours for a couple of hundred quid then i will look gaz!!
dont want a pristine one, as its gonna get ripped to shit anyway...am planning on doing to a turbo everything i was gonna do to mi 480 S, but as they dont seem to be that tuneable, i may as well spend the cash on a turbo!
didnt think youd sell your turbo gaz?????
rgrds
rob
martinholmesuk
Post by martinholmesuk » Wed Mar 09, 2005 1:14 pm
We are talking about the grey turbo right?
