Auto box whooping sound still!!!!!!!
Hi !
I bought my car with a whooping noise from the Auto box between 2nd and 3rd.Changed ATF and cured it.
It started again recently,when under more torque as modded ecu now.
So,I added one bottle of Lubegard (10 US quarts I think??!!!) in with my new ATF.The sound is still there.
Have I put in enough?
Cheers!
Cheers!
I'm No Longer Here :(
- rpruen
One bottle is enough to treat 10 quarts.
I think you have used plenty
One bottle should do for two oil changes, since it's made for american cars (with huge auto boxes). Sorry I didn't think of that before.
One US quart is near enough a liter, 10 quarts = 9.4635295 liters
So when you drain out your fluid 3.5L aprrox goes back in, and 1/2 a bottle is still plenty.
Richard
Richard
Car Status: Squashed :(
Now have 765 GLE 2.8 V6
- rpruen
Mine doesn't either it whines quite a bit in seccond / third thoughchris1roll wrote:My gearbox doesn't whoop
An addativechris1roll wrote: Umm, have no experience of lubeguard, is it a special form of ATF, or is it an addititive to the normal stuff? I.e. could you fill with just lubeguard (not suggesting this is a good idea!!)
It's a heat transfer agent mostly, a synthentic fluid made to have a high specific heat capacity. Thus it cools the torque converter more effectivley. It's also got a package of anitoxidants to help preseve the fluid as well.
Does what I says on the tin as well, I used it before, and it does reduce the temperature of the ATF.
Richard
Nice 1!!!!!
@Ricky switch yer MSN on!!!!!!!!!!
@Chris,its an additive like Amsoil,Volvo/Saab dealers use it to shut up gearboxes!!!!!!!U can get engine oil additive too.It lengthens the life also of the fluid which it is added to!ATF/PAS fluid and axle stuff too for those lucky RWD conversion boys out there!!!!Where are you by the way???!!!
Thx for rapid response!!!!!!
- rpruen
I don't see why not. It may not be so effective as there is less chance of the heat getting out, but it can't hurt.chris1roll wrote:So i could put it in with the power steeering ATF when i do the rack tomorrow then?
especially seeing as how mines an ES with no fluid cooler, with a turbo heating everyhting up....
Richard
