Are problems with the clutch usual? I've had a few problems with mine, plus one of the other 480s i've obtained also has sticky gears (again clutch related). Is this just general age related wear?
I've just found out that before i got my 480, the pedal box was 'bent', the garage claimed to have fixed it, but my clutch went in the middle of bloody Manchester turns out the pedal had actually buckled. This happened to anyone else, or is it just that i have the touch of a baby elephant?
Even reading this back, it seems a little incoherent, but in my current fragile state i can't make it anymore eloquent, apologies
Dicky Clutch
Dicky Clutch
Parts stockpiled for future Turbo project:
Full Theiss Bodykit (requiring refurbishment) inc Front and Rear Fogs
New Rear Clusters
New Clear Front Indicators
Custom Hard Load Cover With 6 Speaker System and 'Cargo Hatch'
Digital Clock
Auxiliary Gauges
New Rear Clusters
Digital Clock
Auxiliary Gauges
- robkendall
hi joel
yeah, my clutch pedal was bent....at the elbow, where it bend to attach to the pedal box, theres a little nick (kind of a semi circle) of metal, this is a weak point.
get tthe clutch pedal from anothe 480, remove the long bolt that goes throught the pedal box, leave the accelerator and brake in situ, and just swap the clutch pedal.
i then put the bolt back in the opposite way, meaning the nut was on the clutch pedal side, in case it ever happened again, i wouldnt have to withdraw the whole bolt.
its not hard mechanically to do, but yuo do need double jointed arms to get in there!!
the cable may be sticking and causing this, as extra pressure has to be applied to get the same result....swap the cable while youre at it....its not hard
good luck dude...any probs, drop me a pm, and i will try to explain a bit more.
rgrds
rob
rgrds
rob
Cheers Pol, Rob, gonna attempt the repair this weekend, i'll let you know how my amateur efforts go!
New Rear Clusters
Digital Clock
Auxiliary Gauges
New Rear Clusters
Digital Clock
Auxiliary Gauges
