Driveshaft pin
Driveshaft pin
Hi all can some tell me where I can buy the shaft pin
Re: Driveshaft pin
Skandix
Re: Driveshaft pin
Only really worth buying from there if you combine it with other stuff as the postage will be quite large. I think their roll pin listing gives the dimensions so you could take this info. and buy in the UK.
If I remember rightly it is actually two rolls pins: one inside the other.
Re: Driveshaft pin
Yes your right outer pin as broke but still have inner would it still be ok to use I need a subframe bush anyway
