B18FP clutch/flywheel size!
cranna21
Post by cranna21 » Mon May 30, 2016 10:46 am
I've had a look through a lot of threads on here but not come up with an exact answer! I have a '91 ES fitted with a B18FP (cat+lambda) what diameter clutch should this have? It's nearing the end of its days but still has a bit of life left but without removing the box ect what size should I expect?
Or is this a question thar can only be answered on inspection?
Cheers!
'90 940 GL 2.0l Estate
'08 XC90 D5 SE Premium
Re: B18FP clutch/flywheel size!
Post by glasgowjim » Mon May 30, 2016 11:44 am
Go on to eurocarparts enter your reg number select parts clutch kits and then click on details and it will give your diameter , number of splines and engine type .
=> problem solved and this weekend they have a BIG discount as well
cranna21
Post by cranna21 » Mon May 30, 2016 11:57 am
You sir are a don,
why didn't i think of that! haha cheers :)
cranna21
Post by cranna21 » Mon May 30, 2016 12:03 pm
quick search shows up as below:
Diamter (mm) : 200
Number of Teeth : 26
Plate Diamter (mm) : 200
Engine code B18 EP
next question i'll need to find an answer too... how to upgrade to 215... :?
alternatively, if i went down the 'custom made clutch' route, i could stick with a 200mm diamter but have a better friction material used? and have the pressure plate uprated?
Post by glasgowjim » Mon May 30, 2016 6:13 pm
cranna21
Post by cranna21 » Mon May 30, 2016 7:46 pm
Excellent! I know what I must do.... Haha
