oil leak from the gearbox
joseph74
Post by joseph74 » Thu Feb 05, 2015 4:38 pm
Hello, i have a Volvo 480 turbo 91, I have to change the clutch, measures are oil seals to change?
The car loses oil for the gearbox.
dagajsek
Re: oil leak from the gearbox
Post by dagajsek » Fri Feb 06, 2015 1:03 pm
First and foremost check if oil is draining throught camshaft's rubber seal, bell. I don't know how that's called exactly.
joseph74
Post by joseph74 » Fri Feb 06, 2015 6:49 pm
OK , when I remove the gearbox oil leak will seek , I think there are two oil seals, that of the gearbox and crankshaft , I do not know the measures of them .
Thank You
