Hello, i have a Volvo 480 turbo 91, I have to change the clutch, measures are oil seals to change?
The car loses oil for the gearbox.
oil leak from the gearbox
Re: oil leak from the gearbox
First and foremost check if oil is draining throught camshaft's rubber seal, bell. I don't know how that's called exactly.
OK , when I remove the gearbox oil leak will seek , I think there are two oil seals, that of the gearbox and crankshaft , I do not know the measures of them .
Thank You
Thank You
