Clutch Question
Posted: Sun Apr 17, 2011 4:35 pm
by kane
In a bid to uprate my clutch as the amount of torque my N/A B18E is chucking out is rediculous and causing major slip, i am now thinking of getting a turbo LUK clutch and have it thrown in.. now the theory is sound but is it pratical? would a standard turbo clutch go straight in with no modification to the flywheel (200mm N/A replaced with 200mm Turbo 3 peice kit?) and would it withstand the power for longer and allow more room for modification or should i look around to get one for a N/A and get it uprated.... looking for a easy and quick win option....
Regards
Re: Clutch Question
Posted: Wed Apr 20, 2011 10:56 pm
by kane
Alrite no reply but i am assuming that the turbo clutch would be a direct replacement for the n/a correct me if I am wrong?
Re: Clutch Question
Posted: Thu Apr 21, 2011 9:35 am
by Captain Slow
They both have the same gearbox, so thats a start...
Re: Clutch Question
Posted: Thu Apr 21, 2011 4:24 pm
by glasgowjim
depends on the size of flywheel wheel .
Look up posts by B18ftlover as rob had several queries about this answered. So check it out there is definitely info on this.
Re: Clutch Question
Posted: Sat Apr 23, 2011 7:25 pm
by kane
From what i can make out if the flywheel accepts a 200mm clutch then any other 480 200mm clutch will fit anyway i am buying it and going to match it up to my old one if it matches it matches if not i'll send it back but i post up my results online theoretically it would be stronger clutch than the N/A but we'll see.....
for added support this might be a good thread for anyone looking to tune the N/A and needs to strengthen this part, although many would say scrap the N/A and get a turboooo.................. i beg to differ!!!
Re: Clutch Question
Posted: Fri Apr 29, 2011 3:56 pm
by kane
Re: Clutch Question
Posted: Mon Oct 10, 2011 2:15 pm
by kane
Ok i know i am reviving something a couple of months down the line, but as the 480 is now off the road i can confirm i did have the turbo clutch put on it and what a difference it was, wheel spinning everywhere but it was much fun........ so yes on a standard 1.7 N/A you can fit the turbo clutch which did take much more poundage!!! Just a thought for all those N/A fans who want to the 480 to do more!!!
Regards
Re: Clutch Question
Posted: Mon Feb 27, 2012 10:54 pm
by felyx
If you take out your old knackered clutch , and send it by post to any number of companies
, i use FRICTION SERVICES in Keynsham nr BRISTOL . They can over night ( good for your daily driver ) re surface the clutch plate in a racing compound at any thickness you like , i go for 1.5mm over standard for £25 !!!!!!!!!!
also if you havea spare pressure plate (this takes 10 days ) they can increase the spring pressure by up to 50% for £50 ! so for £75 you get a 300BHP clutch . I have done this 3 times . NO MONEY ON EARTH SPENT CAN BETTER THIS SOLUTION > ADMIN < make this a sticky will you please . Cheers Tim . the 480's are getting less and less
