The clutch pedal on my 1.7S (L reg) is about 2 iches higher than the brake. I think it looks like the cable can be adjusted to correct this and I know the last owner had a new clutch not many miles ago.
Can I adjust tjhe cable to do this? or is it another issue lurking. The clutch has good bight and is progessive.
Clutch Pedal Adjust
Re: Clutch Pedal Adjust
As i have to work on this issue the next days, too, i just wanted to throw some information in:
with ABS System the Clutch pedal should be 25-30mm higher than the Brake pedal.
without ABS it only has to be 15-20mm higher.
thats what volvo says in its books.
Turbo "Collection 306/480"
two wrongs dont make a right, but two wrights make a plane.
