Looking at a 300 series volvo and it had welded rear differential , know what it does but how does it feel driving one of these as opposed to a non welded diff?
just a thought
oh do the 300 series wheels fit the 400 series cars?
general enquiry abou differentials
Not recomended for on road use, if it has a welded diff there is a high likelyhood its been drifted or that was the intended reason for welded diff.
When a car is driving down a road with a welded differential, the tyres are spinning the same, when going into a turn, instead of a slide gear shifting, it stays completely locked up, making both tires spin at the same rate, causing you to lose traction very easily.
'88 Volvo 480 ES
'97 Volvo 940 Turbo
'97 Volvo 940 Turbo
