Hi all,
can anyone help with what would cause the clutch arm to be loose in all directions and how this can be fixed? Also, should there be any spring mechanism to pull the arm back?
The car is a '92 1.7 NA ES
leon
Loose Clutch Release Arm
Wobble = Normal
Don't sweat it...
The release arm just pivots on a metal sphere it's tethered at the
release bearing (where it sits in 2 guides in the bearing carrier) and
at the other end where it is held by the clutch cable.
When it's not under tension it will wobble about a bit. Have someone
depress the clutch (tell it it's inadequate and it's mother never loved it)
while you observe the release arm. You should see it move properly
and at full travel will be non wobbly (mind your fingers!)
C
Don't sweat it...
C
