Clutch cable fitting (new 93> type)
hailesmail
Post by hailesmail » Sat Dec 15, 2007 5:57 pm
I tried to replace the clutch cable today, and while footery it loks straightforward enough, however when everything is lined up at the pedal end, the barrel on the end of the cable will not slide into the hole in the lever on the pedal.
It looks easy enough and I've had the cable lying right along where its meant to go a few times, but always the fit is too tight
How tight is it normally? Could the fact is is so cold just now have made it even harder due to the metal contracting?
Any advice would be appreciated
Tip: Forget Norton and Macafee, click for the best Antivirus and internet security software https://secure.avguk.com/aff/doc/1/lng/uk/aid/1956/
marksch
Post by marksch » Sat Dec 15, 2007 8:57 pm
Hi there hailesmail,
replaced mine yesterday, so still fresh in memory;
won't slide in this way for a good reason, would slide out just as easy.
if you look at the lever as beiing in vertical position, line up the cable
but then bend the top end, so the barrel goes in the lever-hole with the cable in horizontal position as in top-end of barrel first.
Then when inserted push the cable 90º down, then the barrel and
cable will slide in thus being locked against sliding out.
hope this will help.
Mark
For now no more 480's : maybe some day ....?
480 Turbo 94, green 314, sold 2008
480 GT Turbo 95,SRE clutch, Richmod,sold 2008
480 ES 87, red 217, sold 2005
480 ES 87,blue 219,dismanteled and sold 2004
hailesmail
Post by hailesmail » Sun Dec 16, 2007 1:22 am
Thanks a lot, I actually suspect this may be the way, but didnt want to kink the cable, I'll try again when i get time to have another go and let you know how it goes.
JohnTurbo
Post by JohnTurbo » Sun Dec 16, 2007 1:41 pm
marksch:-
How about an introduction?
Past:
94 Turbo - Red
92 Turbo - Red
90 Turbo - Silver
Now:
00 Exige
15 GKD Legend
16 Skoda Superb
marksch
Post by marksch » Sun Dec 16, 2007 2:46 pm
John Turbo,
i understand this being a common courtesy and it is in General Discussions
just now.
Yesterday just wanted to give a quick answer and skipped it.
Greetz, Mark
macaroni
Post by macaroni » Tue Dec 18, 2007 1:19 pm
This is a horrible job and to give you enough inner cable to bend 90degrees, make sure you have pushed the outer cable fully into the bulkhead.
I didn't at first and it caused me all sorts of bother.
Oh, and welcome!
robkendall
Post by robkendall » Tue Dec 18, 2007 8:15 pm
i found it easier to remove the clutch pedal from the pedal box, the fit the cable in, attach the cable at the fork end on the gear box, then replace the clutch pedal....is a lot easier than fiddling around upside down.
remove the instrument cluster so you can see what youre doing with the pedal box too.....is soo much easier.
rgrds
rob
480_rocket
Post by 480_rocket » Wed Dec 19, 2007 10:29 am
I did what robkendall did, there was some photos on here of how to undo the bolt at the top. Requires sticking loads of socket extensions together!
One of the tricky parts I found was trying to get the rubber grommit into the bulkhead and also the other grommit on the bracket near the clutch.
