Duke of Cruel
Post
by Duke of Cruel » Mon May 07, 2007 9:02 am
Hi guys,
what is the best synthetic oil for the manual tranny? And has anyone put in an tranny cooler?
DoC
Volvo 480 1990, Vovo 855 t5
VanDerGraaf
Post
by VanDerGraaf » Mon May 07, 2007 11:48 am
Millers TRX 75w 90 is good and safe- you have to make sure whatever you use meets the spec otherwise you can kiss your bronze components and box goodbye.
Otherwise the official Volvo stuff will do.
There are bound to be others that meet the GL5 spec but that's research for another day....
Amonra
Post
by Amonra » Wed May 09, 2007 8:35 am
i contacted the Maltese distributor for millers oils and he told me that the Millers TRX 75w 90 he has is a semi synthetic oil.
I am not really sure but is it equally good , or it will damage my manual tranny?
Ettore Bugatti
Post
by Ettore Bugatti » Wed May 09, 2007 10:19 am
Renault boys use transELF.
Rover Mini 1000, june 2009-
derek uk
Post
by derek uk » Fri May 25, 2007 10:55 am
Manual gearbox.......
GL-4 good - Redline MTL works well.
GL-5 BAD - Additives in GL-5 corrode bronze/yellow metals such as syncros and will damage your box fairly quickly. Damage to your wallet will follow shortly after.
JohnTurbo
Post
by JohnTurbo » Fri May 25, 2007 11:31 am
Volvo stuff @44quid and TRX @25quid are the only options we know are safe.
Past:
94 Turbo - Red
92 Turbo - Red
90 Turbo - Silver
Now:
00 Exige
15 GKD Legend
16 Skoda Superb
VanDerGraaf
Post
by VanDerGraaf » Fri May 25, 2007 6:20 pm
derek uk wrote:Manual gearbox.......
Erm, not according to Volvo specs.
Read
This.
Or
This.
Perhaps not all GL-5 spec oils contain the same additives. I spoke to a guy at Miller's Oil and he said their oils are safe for bronze components, as the modern additives they use don't have this problem.
