Clutch kits- what fits?
- VanDerGraaf
Simple question really- does anyone know if any clutch kits for other cars fit the 480 Turbo (somehow Renault springs to mind).
Rohan
Rohan
08 Renault Laguna III Sport Tourer 2.0T 4 wheel steering madness
00 Citroën XM ES9 V6 incredible
Previously:
00 W210 Mercedes E430 V8 estate LPG .....wünderbar!
00 W210 Mercedes E320cdi estate dead, eaten alive
95 Citroën XM 2.5 TD estate dead
95 Citroën XM 2.1 TD stolen/dead
'97 Saab 9000 Aero gone
Vase Green '94 Twin Pipe 480 Turbo
"Scar", Vase Green '94 Turbo dead
"Green Goblin" '93 Turbo Auto PITA, dead
Grey '88 ES dead
Steel Grey '93 480 Turbo sold and believed dead
Previously:
Grey '88 ES dead
- Ally
Would make sense, wouldn't it... It is a Volvo gearbox though, and in their infinite wisdom they probably made the spline on the input shaft different so you have to buy a specific clutch.
Would be interesting to know though...
Fred - 1995 480 2.0i ES - Dark Green Metallic (106,000 miles)
Dave - 1993 480 2.0i ES - Steel Grey Metallic (148,000 miles)
- 480 Veteran
Turbos got two clutch sizes 200mm and 215mm. There are alternatives from Renaults.
The Renault 5 Turbo for instance is 200mm, but the Volvo one is actually stronger. Then again you can get a lot more options for clutchs on Renault 5s, paddle, organic, sintered etc.
Renault Clio 2.0 16v and Williams came with 200mm or 215mm depending on the year or as I think they call it, 'phase'. Again, quite a few options.
Look for clutchs with 26 splines and 22mm, some prety hefty clutchs here
http://www.helix-autosport.com/groupa.asp
- VanDerGraaf
Yeah Rocket, this is along the lines of what i was thinking....hmm, options!
Perhaps unwise for a non-techy like me to consider but obviously someone else'd be doing the fitting...
Hmm, paddle clutchs don't seem to last too long....
Previously:
Grey '88 ES dead
Previously:
Grey '88 ES dead
- robkendall
much better grip though.....VanDerGraaf wrote:Hmm, paddle clutchs don't seem to last too long....
rgrds
rob
Ok chaps this what i'm up to right now... Richard's ordered me a kit for the later larger clutch set up. The strongest combination consists of the volvo cover/press plate and a renault williams clio friction disc. Anything else will not cope with large power hikes... hope that clears things up, Edd
1993 Es, turbo conversion. First ceramic coated engine running sweet. Sold! :( miss her
www.teamvolvo.co.uk
www.teamvolvo.co.uk
Indeed Rohan!
I'll 2nd that!
When mine goes to the Burnham School of Box for a good old twitching,it'll be Clio Williams 2 clutch plate,the Volvo cover and a carbon fibre Sachs release bearing.All courtesy of Sachs.£85!Splendid......
I'll 2nd that!
I'm No Longer Here :(
- VanDerGraaf
Groomus, post or pm me the details if you can! Sounds exactly what i was looking for!
Previously:
Grey '88 ES dead
Previously:
Grey '88 ES dead
- chris1roll
- alfonzobonzo
The box i just took of my non turbo even has the Renault diamond on the casting. Laguna parts mostly i think.Ally wrote:Would make sense, wouldn't it... It is a Volvo gearbox though, and in their infinite wisdom they probably made the spline on the input shaft different so you have to buy a specific clutch.
Alfonz.
Toyota Celica G7 Tsport Storm Blue (LiftTastic)
480 L 1994 2.0 i Metalic Black K&N Panel SOLD (fond memories)
V40 W 2000 1.9 T4 SOLD (kind of miss it)
- 480 Veteran
- VanDerGraaf
So really you could fit a Clio 172/182 clutch and it would be strong enough to take modded tourque then?
Previously:
Grey '88 ES dead
Previously:
Grey '88 ES dead
if you have your old clutch plate you can get them resurfaced in a tougher compand and i did my last 1 at 1.5mm thicker than standard , this cost me £25 cash and they could of reconned the pressure plate and made it 35% stiffer and stronger than standard for £45 this work is done by "FRICTION SERVICES" in warmley bristol, but just look up brake /clutch re lining in your local yellow pages and if your first number can't help they will know somebody who can, and on a huge plus side the company i use is a 24 hour turnaround on clutch plates and 72 hours on strentging the pressure plates.
cheers felyx
cheers felyx
