Today after a long time of anoying wet windows i decided to repair the VEM, i removed the vem and have taken a close look at it also inside, al the solder jonts where in good condition, so i placed it back on it's place, closed my eyes started the engine and waited for the the blower to start working, but nothing.........
But what i do hear when i push some of the buttons is the sound of a relais like clikking on the left of my dashboard somewhere near the fusebox it seems, and i hear a tiny verry tiny whistle at the rear of the vem, now i am wondering, could it be a broken relais????
Please help me...
silence at the VEM
Hi Johan
To help you.
The VEM´s main function is to regulate the airstream and the airco if you have one.
The blower function is also partly regulated by the VEM. It is that level 1 and 2 or 3 if present are routed via the VEM and full is routed in bypassing the VEM.
My advice is or get a good working VEM or reroute the power to the blowerswitch and using a blowerswitch with a proepr working 0 position.
Good CEM
Gerrsvolvo
To help you.
Good CEM
Gerrsvolvo
Re:
So you mean if my blower only works on full (pos. 4) it has been bypassed? I soldered a contact on the VEM because it didn't work at all, when I put it all back together, the blower only started working when switched to 4, nothing on 1/2/3. The switch worked fine before the VEM failure. And I see 2 connectors going to the fan switch, the main one with several pins and another with 2 pins, which I'm guessing is the light bulb for the switch (mine broke), so I don't think it's bypassed... Hoping it's the resistor, purchased one this morning. It does blow hot air no problem, albeit with a rattling noise from the blower (only on slider full right) that would drive anyone nuts.gerrsvolvo wrote: ↑Mon Jan 05, 2004 7:37 amHi Johan
To help you.
Good CEM
Gerrsvolvo
