Today after a long time of anoying wet windows i decided to repair the VEM, i removed the vem and have taken a close look at it also inside, al the solder jonts where in good condition, so i placed it back on it's place, closed my eyes started the engine and waited for the the blower to start working, but nothing.........
But what i do hear when i push some of the buttons is the sound of a relais like clikking on the left of my dashboard somewhere near the fusebox it seems, and i hear a tiny verry tiny whistle at the rear of the vem, now i am wondering, could it be a broken relais????
Please help me...
stil no vem response
- volvofox
should be quit repairable. But you have to know what youre doing. Best is to download the dutch electrical schedule at the site of member Dragon. It also explains which relay in the relay box it can be, which fuses there are, which connectors have to be examined, etc. etc.
By the way, windows that turn damp very fast is an indication that there is water leaking in the car, and the mats are wet from beneath. Than you have a high moisure degree in the car.
Are you the same "johan" from the belgian Msn 480 club ?
so download, and make some copies from the electrical schedule at http://volvo480.northernscum.org.uk andrun down the track like a map. Its easy. Check every component you find on "your way"
luck,
JPF
Nomen est Omen
JPF
Nomen est Omen
Thanks in advance
As i am writing this i am downloading the pdf file of the electric scheme, thanks for your info, if this will do the trick then i'll shurly will let you know, if it doesn't then i'll keep on trying.
It could be possible that i am the same johan as the one from the belgian club, i've been al lot of places on the internet.
member no 0041
1989 Volvo 480 ES
graphite grey colornr 304
www.johanbaremans.com
1989 Volvo 480 ES
