![Sad :(](./images/smilies/icon_sad.gif)
Ryan
the dimmer switch still works and will adjust the illumination of the info centre, but still no digits!VOLVOGT wrote:check the dimmer switch under the steering wheel. When mine blanked it had burnt the switch out.
this sounds interesting ... i shall investigate. If you can expand on this, please do!!billy5000 wrote:(check fuses hanging on blck plugs under the dash above the pedals right side.(maybe worth a look)
I'm not 100% sure at this moment, but I was just about to post a question about this, as it looks like it is exactly what happened in my car: Why on earth would the IC be wired through the stereo unit? A friend and I put in my Pioneer cd changer and head unit yesterday and after all was said and done, there was one grey sleeved wire left dangling and we had no idea what it was for. As we were working on the stereo, we were thinking and looking in that direction and never thought to check anything else. As I drove off today I noticed the IC was all lit up, but not displaying any info. All fuses look fine and all the lights in the dash are still functional. And since it stopped working, all that changed is that wire hanging there not being connected. Will connect the wire tomorrow and report back if anyone's still interested1900sr wrote:Just spent the afternoon sorting out my dead ic. On my car, the main power feed for the ic was looped into the original stereo plug (two wires into one terminal). The previous owner had chopped this about to fit his stereo, and cut the live feed to the ic. I re-made this connection and all was fine.
hi stu,stu chacks wrote:
Engine temp is normally measured by the water coolant temperature is what I meant Mart, although being a Volvo wouldn't suprise me if uses something else.
Will pinch one off a scrappy 480 when I head over the weekend and swap and check, cheers amigo.
You can always find a job with a 480 huh!
Stu.
