Rear bulb failure warning light
All the rear bulbs seem to be working, but the bulb failure light is staying on.....is there a way to reset it??
- Brasco
The bulb failure is attached to your DRL's too. If one of those is out, it'll stay on.
- Brasco
your Day Running Lights, dood (at the front!)! They're dual filament too, so check 'em with your pop-up's up and down. Should be brighter when down.
Hope this helps!
Hope this helps!
Hi all
dont the brake pedal get the bulb symbol out or am i thinking wrong light?:)
i take it the bulb symbol next to the water symbol is what light you mean?
sg
sg
480 for life!!
1X)2 tone (silver/green)480ES 92 1.7i (140.000miles)(dead!!!
1x 480 es two tone silver/green 1992 1.7i(126.000)alive!!!godlike:)SOLD:(
- Agwa Moose
- Brasco
http://volvo480.northernscum.org.uk/
The circuit diagram is in the download section on Dragon's website. Very useful.
Basically, when you press the brake it completes the circuit that, if all the bulbs are working turns the warning light off.
Check your central brake light is working... somehow it's easily overlooked.
Ive checked all bulbs are working.....only thing is, although there are 2 rear foglights fitted to the car only 1 of them has any wiring connected to it.....is this the norm?????
Also, ive fitted new DRL bulbs....are they supposed to go dimmer when you switch your main lights on???
Grrrrrrrrr....frustrated!!
- Brasco
Yeh, only one fog light, apparently it's the law these days.MISTA wrote:Ive checked all bulbs are working.....only thing is, although there are 2 rear foglights fitted to the car only 1 of them has any wiring connected to it.....is this the norm?????
DRL's are supposed to go dimmer when your headlights are up.
I'm out of ideas I'm afraid.
- Brasco
DOH! Just read your windscreen wiper thread, it's the wire harness that's causing your bulb warning light to stay on.... the cable that connects to the middle brakelight is in that harness. If the insulation is off, water will have got in.... fix that and I promise, all will be well.
(well... perhaps promising that is a bit too much! )
- guitarcarfanatic
Yeh older cars got 2 but volvo only fitted one proper one to later cars to save production costs. Here in the Uk by law you only need one foglight on the drivers side of the car(or the middle of the car).Brasco wrote:[
Previously...
1989 Black ES - Great runner
Previously...
- MGB_GT
I read somewhere that the reason cars have only 1 fog light at the rear is to do with the eye being able to see red. Some scientific study along the lines that everytime you see bright red, it damages the eye in some way. Prolonged expore to a bright red can actually make it more difficult to see red later on. Therefore it was introduced to only have one rear fog light (I think it's law also) on all new cars to reduce the risks. Best guess on the 2nd light, well it would look daft with only one there and as you don't generally use them, it wouldn't be a big deal that only one off them actually worked.
Penelope - 97P Rover 618 Silver
The departed:
480GT - 94L Dark Green Met
480ES (2.0) - 93L Vase Green Met,
480ES (1.7) - 89G Black
480ES (1.7) - 88F Gunmetal Grey
The departed:
- Brasco
Ya lazy arse! Well, in that case I'd say it's a dodgy connection.MISTA wrote:Lights gone off now.....not sure how, i didnt touch anything!!
