if the info center missies some volts, I mean there are not enough due to unsufficient ground (I heard you speak about some voltage at the radio wires, the must be at least near 12 volts !
I don't believe its the halogen, since you would be able to see some. at least with a torch.
I think its a dirty connection somewhere. either the ground, or the current. any ways, it sill can be broken 18 pin connector weldings at the inside of the clockhouse print
CEm dead
thanks all well. Have the day off tomorrow so will attack it from all angles
.And hopefully get things sorted out .gor new bulbs for running lights . and they will both light up with full brightsness.but when try to puty up lights.One goes dim and the other goes off so belive its wiring or connectors not reley but will update tomorrow cheers all
