Help no brake lights
Can anyone give me an idea what to look for have checked number 5 fuse which I think contols brake lights and auxillary cooling pump.Noticed I used to get a clicking sound when applying brakes cant hear that now.Is there some relay or switch that may be faulty.Hope someone can help.
Cheers John.
Cheers John.
Yeah, if i remember rightly, you've got to do a sort of headstand into the footwell, put 1 leg on the sunroof, and another out the passenger window. Put 1 finger in the cigarette lighter socket and bend your back. Using your free hand, you might just be able to unscrew the awkward bastard switch thing!
Have fun!
Have fun!
help no brake lights
Thanks for the suggestions will try and get to brake switch today another problem occured now since I was trying to fix lights last night now both indicaters come on when I turn indicater on will look in daylight today hope its not raining.
Hi John Denmead
Do not be afraid.
The indication to left or right direction does (I am pretty sure) not work via the CEM. The blinking itself goes via the CEM.
So if the indicators are blinking, the CEM is Oké.
Maybe some connectors have been wrong or not good been been put together in the dark.
Good Luck
Gerrsvolvo
Do not be afraid.
Good Luck
Gerrsvolvo
- volvofox
mwoa, I dare to relativate this. the first time i went to a scrapper for 480 parts I was lucky to find the exact same CEM, so I bought it rightaway, because everyone was saying this was the worst aspect of the car, causing the most trouble. I have it laying in my workshop closet for 7 years.
Of course I try to swap it when I have trouble, but every time it is something else, something stupid like bad grounding, dirty connectors or switches....
Aldough it is thue it regulates the funniest things in the car, if not all, I am not that prejudged.
luck JPF
btw ECU means simply Engine Control Unit. You will never forget again.
luck JPF
luck,
JPF
Nomen est Omen
JPF
Nomen est Omen
