current
- Ettore Bugatti
current
It is commonly known that the current in rest should be 0,03A. I have test this on my mothers car and the resistance was 42 mOhm. Still my battery goes flat and the alternator has a resistance of 42 mOhm and the rest of the car has no resistance and thus no current. I known that the alternator is flat, but no other sources of drain is also very strange.
Hi Ettore,
I am sure that there is some information on testing the power consumption on the Vadis DVD. I have not got the time to check at the moment. Unless someone else can do so I will do at the earliest opportunity.
However, have you checked the power consumption (Amps) by putting an ammeter in series with the battery?
There are lots of sources of power drain on these cars which once again is explained on the DVD.
Best regards
Chris
Best regards
Chris
- Ettore Bugatti
