Ive finally put my new passenger side solenoid in,and still my central locking wont operate using drivers door lock!
Any ideas anyone???
Central locking still wont work!
I'm No Longer Here :(
Hi!
If you have a 480 up til 91, you have a switchbraker in the drivers door. You shoud be able to hear the contacts working when locking/unlocking the door. This unit sends a signal to the pass doormotor. The switch has a timer function and operates for a second.
Its not unusual you have a cabel break in the door/chassie opening.
/Jonas
/Jonas
Engineer
- Murf
yes, bit he's getting a voltage reading at the wires at the pass side motor when he locks/unlocks the drivers door. did you try the motor with the wires connected but with the linkage disconnected??
maybe the linkage is bindige with the way you fitted it and stops the motor working??
Kia Pro'ceed GT 1.6 Turbo
1992 480 Turbo
2007 Focus ST
1992 480 Turbo
2007 Focus ST
