Very strange,
I finished my Fencing practice (swordfighting)
Started my volvo to let her warm up (it was freezing) and after she had been idling for about 5mins the engine just slowed down and stopped and all the interior lights were dim. I tried to restart her but there was just not enough power to turn the starter motor (though it was trying) I push started the car and it was fine after that. After 2mins driving she started as ussual.
Any ideas?
Sudden electrical power loss while engine was running !
1996 Mini Classic 1275.
- dragon
- Volvo 480 Club Europe CREW
My immediate ideas:
1) Bad earth somewhere affecting charging
2) Bad altenator voltage regulator
3) Bad altenator brushes
4) Bad connection in altenator/battery
5) Bad battery
You seem to descrbe the car starting and running entirely on battery charge which naturally ran down to a stage the running of the car was interrupted so it seems like you have no charge being generated at that time. As you say all was well after a push start, it may be a bad connection - so check and double check all wires, copper grease the battery terminals and check as many earths as possible. Beware the altenator cables are brittle inside and can crack, causing an intermittant problem like this, even though they look fine from the outside - mighyt be worth going along all your cables flexing them slightly to try to detect a fracture...
Other than that do the usual checks for bad altenator/battery, as a one off problem may hint at overall deteriating health in the charging system. Start her, then get a volt meter and check the charge in volts at the battery terminals as she starts and runs then check the flow (ampage) from the altenator and compare with the values in the Hatnes manual - if you have charge at or above the normal values as it runs on the altenator, then it is likely the battery at fault (higher than normal value indicated altenator is running extra hard trying to charge the cells) - Check the battery liquid levels and top up with deionised water if necessary - might be worth getting a battery charger and trickle charging the battery out of the car for 12-15 hours, you can tell if the battery is knacked by the ampage the charger runs at as it charges (or tries to) - It could be that a fault in the battery has caused a fault in the altenator (or vice versa) and you need to replace both (if both are old, it'd be worth your time and money replacing both at the same time anyway)
5) Bad battery
Gaz Wilson
Gaz Wilson
- strangegame
