Oil Pressure & Voltmeter Guages Revisited
proud480owner
Post by proud480owner » Tue Nov 11, 2003 1:28 am
Hi
I gather from the previous posts on this subject that if I get a unit from a breakers yard I should be able to plug it into a 4 pin connector lurking beneath the radio. I've checked on my '92 ES and I've only got the 4 bare wires: yellow, brown, brown/blue & white/grey. None of the breakers yards I've contacted have still got the car to cut the connector block out of. Any idea what the Volvo part number might be for the 4 pin connector I need?
Cheers,
Andrew.
tfmorton
Post by tfmorton » Tue Nov 11, 2003 12:24 pm
you mean the 4 wires arn't terminated in a plug already?
Ford Probe 24v V6
Ford Mondeo 16v
but no longer a 480 owner
chris1roll
Post by chris1roll » Tue Nov 11, 2003 3:25 pm
looks like the previous owner of your car took the guages with th em.
When I put the guages in my old 440, I used insulated spade connectors and crimped them onto the pins on the back of the guages. works just the same, you just have to work out which wire goes where.
