Alarm
- Ettore Bugatti
Alarm
When I parked the 480 ES I always cut the powersupply off by a safety switch, but when I last installed a other CEM the problems began. If I want to drive this car(who doesn't, here?) I unlock the drivers door, have a seat, put the power back on, want to put the ignition on, but the alarm has been awakened, which is a bad thing because the sound is not very nice. Now I have disconnected the connectors in the doors and no problem when entering the car. My question is: Are the doorswitches operating correctly?
- volvofox
do you have a ground switch on the battery, like on building machines ?(to prevent battery drain, fire etc)
If you open doors and than switch on the ground connection to the battery, of course the alarm goes off.
Please explain what switch you made here.
Luck
JPF
Ps Did you have the right CEM ? they are not compatible. check serial numbers and connectors.
There might also be a bad connection on the new CEM 's connectors.
I had a problem too after swapping cems, but i did not mount the Big A connector right....
Luck
JPF
luck,
JPF
Nomen est Omen
JPF
Nomen est Omen
- Ettore Bugatti
It is a ground switch, because the car has a serious battery drain. The CEM had the same numbers so that shouldn't be the problem. I have now disconnected the connectors in the doors and the problem seem to be gone.
The most odd thing here is that when I installed the CEM and parked the car and later had a drive in it the alarm didn't go off.
Also very strange was when I disconnected the connectors in the doors. The next time I wanted to drive the horn/ alarm sounded but not for very long more like that you shortly touched the horn which I wasn't clearly not doing. I pulled the hornfuse out drove it. Back home I parked it pull the groundswitch off and the next day I put the fuse back in drove it for half an hour and no horn heard.
BTW the groundswitch is from Hella so the electrics should like him
Hope Im clear enoff
Hope Im clear enoff
- Ettore Bugatti
end quote.
but the next time I took the car for a spin the horn made noise. So Im completly lost
end quote.
- volvofox
No youre not lost at all.
just start looking and testing.
I had a drain too, and it was cause by dirt between the contacts of the door microswitch. Its a lot of work, but your problem will be fixed only if you check up the doorlockswitch system (also hatch and hood) The drain should be 0,003 Amp (hook a multimeter in the right setting between the mass pole and the mass clamp, with everything off. in the car.....
Keep us informed
Luck
JPF
Keep us informed
Luck
JPF
luck,
JPF
Nomen est Omen
JPF
Nomen est Omen
- Ettore Bugatti
Had spend some time on the Volvo. It got a new alternator and battery. I put the fuse back to test the alarm. The fuse melted and no horn sounded. Checked the horns both were broken. Put a lamp between the fuse test the alarm. findings are:
You can put the power off and lock the door and then unlock it, put the power back on without the alarm going off
If you activate the alarm after 30 s it stops or it stops when you lock and unlock the door.
Had a look on the horn switch. The plastics was in very bad condition probably that cause the sound. Alarm problem solved I guess
HI Everyone,
Unfortunatelly i have the same problem with my 89' turbo, but i couldn't solve the problem yet, i'm just disconnected the horn's connectors. The alarm system doesn't work, and actually the situation is the same with the horns.
I will try to learn from the previus messages. I will try to keep you informed.
Peter
Peter
ok, but why it doesn't work properly......
