Like it, we now have three 480's, 1 turbo,1 2.0litre and one turbo.
But the normal 1721 that I drive for the time beeing has a major problem;
the headlights sometimes go out. The headlights stay in position, but they sometimes go out and after a few seconds go on again.
Not amusing when youre driving in the dark.
It is a 1988 1721cc with the B18E engine.
Sometimes when they go out I hear a click (relais under the bonnet maybe???????) or faulthy wiring behind the dash ????
Last week I drove over the highway and in a half hour they failed about eleven times. Sometimes they work perfect.
What the hell can this be or has somebody had the same problem ???
I already ordered a new relay.
Thanks and greetz
failing head lights need help please
- volvofox
good idea, start with the relay.
I had the same problem solved with the relay.
Try this: if its out, leave car running and the lights on, then open hood and triangular box near the left hinge of the hood. Gently tick on each relay (or better look on the downloadable schedule via this site (on dragon's) which one is the popups lights on relay). Maybe just a loose, dirty or pushed down contact, but possible needs a new relay.
piece of cake. but it gets interesting if it is not the relay......
luck,
jpf
luck,
jpf
luck,
JPF
Nomen est Omen
JPF
Nomen est Omen
re:failing headlights
From your description I conclude that the relais in the relais box
is most probably the reason for your problem.
I have also had this.
and after fitting an new relais everything was OKE.
Presuming that the fuses are OKE.
Another cause could be the headlightstalk.
Try first the relais. Is cheaper them a new collumstalk.
Good luck
Gerrsvolvo
Good luck
Gerrsvolvo
try the relay first...sould be a little picture in the Haynes book...if u're like me...lost as soon as u open the bonnet lol If it's not that I would have thought that there may be a wire that's giving up the ghost, but the clicking usually means relay...
480 Turbo > 1989 Graphite Grey
MR2 MK1 > 1989...
[img]http://membres.lycos.fr/cosworth/la_team-bordelaise/Sophie.gif[/img]
MR2 MK1 > 1989...
relay
thanks for your reactions.
Well; I already know what relay it is, drove to Volvo Eindhoven.
They helped me out of three problems sofar and it didn't cost me a thing.
I already cleaned the contactpoints of the relay, but that didn't help.
But: what is the function of such a relay; what does it do ???
And don't probably in this case ?????
Thanks very much and greetz
