The first order of things to fix is the indicators, they are all dead (left, right, hazards and both on the dash and all external). Since the car was inspected and deemed road legal as recently as this summer, it can't really be all the bulbs failing since then. And since I also hear the periodic clicking I know the relay is going. It shouldn't be able to be the fuse, but I checked it anyway and it's okay. With this information, a look at the schematic pinpoints this to either the relay in the CEM not making contact when closed, some soldering issue related to that signal or wring at CEM output B4.
So now all I need to do is to grab the CEM and have a look inside (unless the wiring to it is obviously bad). So where is it then? The FAQ on this amazing website is pretty clear:
I also found an image on a French forum that seems to agree:
However, my CEM doesn't seem to be accessible behind this cover. However, I do see the edge of some electronics box that seems very hard to get to. Is this my CEM? Is it supposed to be up there? Can I get to it without removing the entire dashboard? It was held on by a single screw in the lower right corner and I removed that one and tried to wiggle the CEM out, but it hits the edge of the dash. I would like to avoid breaking something on my first job
It also seem to have a different connector from the one I posted in picture 2, does anyone have a pinout for that?
