VEM guru?
VEM guru?
Is there a VEM guru I could take my car to? I’m
In East Sussex but can travel. I appreciate there are guides to help and assist but I also see that they can be a little tricky to spot poor or dry solder and I don’t have a soldering iron and would rather get it done properly first time than faffing round myself. Symptoms are, no life at the fan switch but fuse is okay.
Re: VEM guru?
What happens if you press AC max?
Re: VEM guru?
I’ll check over the weekend and let you know.
Re: VEM guru?
From what I can recall when on FULL blast the three/four way blower switch and all the 'gubbins' in the VEM are bypassed and fed from a different supplyArcticTony wrote: ↑Sat Oct 26, 2024 2:47 pmSo the blower comes on full blast but no control on the fan switch.
What does this suggest?
I must confess to wimping out on any attempt at resoldering and fed the switch from the 'other supply' as the actual 'A/C unit' is toast anyway. .. . . ..
Re: VEM guru?
Yup, I don’t want to get into soldering either which is why I’m wondering if there is a go to person who has experience with the VEM and could diagnose and fix for me.
Re: VEM guru?
From memory, and it's been 20 years since I had a 480 with a VEM, they're quite straightforward to resolder.
White 1990 480 Turbo Auto
Re: VEM guru?
Yup, it’s resolder time: there’s an FAQ about it on the “original” site (that people forget about!) - shall try and find time to build it into a forum FAQ
start here
Then navigate to section 30, ventilation system doesn’t work sometimes.
start here
Re: VEM guru?
Thanks for this. I have seen the guide already so my plan is to share it with a local auto electrician who works on classics, hence my question about whether anyone knew of a go to guru who knew the VEM well rather than someone who doesn’t. Will see how he gets on.
Re: VEM guru?
Ha! I found my guru. VEM fixed and working. Toasty warm car now and all dismantled and remantled without any plastics damage too.
Onto the next jobs.
Onto the next jobs.
