LH Side window regulator needed!
AdamG
Post by AdamG » Mon Mar 28, 2022 2:57 pm
I’m a bit of a newbie here (understatement) but, would anybody happen to have a left hand side window regulator laying around? Just managed to fix RH window, the switch was a little toasted but after removing some residue from the switch in the centre console it’s working fine now. Left hand said however is the regulator. Had an auto-electrician to confirm this so now I need the LH side regulator part. If anyone can provide the part (or help source one) that would be splendid!
Many thanks in advance,
Adam :)
Re: LH Side window regulator needed!
Post by dragonflyjewels » Mon Mar 28, 2022 5:39 pm
Hello Adam and welcome on board. I can't help with a regulator but this is the best place to find one. Good luck !
