Diagnostics not working and SRS light
GCooper
Post by GCooper » Tue Aug 24, 2021 12:33 pm
I have an SRS warning light and the diagnostics box isn't working so I can't find the problem, I followed the advice on here about plugging the wire into connector 7, turning the ignition on but leaving the engine off, and then holding down the button 1-3 seconds but the light didn't flash.
Can anyone tell me how to make the diagnostics box work, tell me what I'm doing wrong, or give general advice?
I'd rather not just take the SRS bulb out but it looks like I might have to to pass the MOT
'94 Volvo 480 GT (project)
'98 BMW Z3 (daily)
Re: Diagnostics not working and SRS light
Post by dcwalker » Wed Aug 25, 2021 7:15 am
Does the diagnostics box work on any of the other positions? Or is it completely dead? Depending on that the advice will differ.
Without more, I'd suggest that your SRS problem likely to be the contact reel spring behind the steering wheel...
Best
GCooper
Post by GCooper » Wed Aug 25, 2021 12:34 pm
I think none of the positions work
'98 BMW Z3 (daily)
