Hi all.
does anybody have a decent working ignition barrel plus steering lock and key they want to sell please.
mine has completely locked up and im going to have to break it unless somebody knows how to get into it any other way.
cant move the steering wheel at all not even the normal amount to release the lock.
440 2.0 1993
ignition barrel locked
440 Turbo
480 Turbo
both 1993
480 Turbo
both 1993
Re: ignition barrel locked
I think they can be released, but maybe you need the key inserted?
I'll check with HBOL and revert with a private message if OK?
OK
I had a quick look at HBOL and sadly you need to be able to turn the key to position TWO to be able to remove the lock . . ..
I f it has stuck completely then you'll need to drill out the snap off bolt heads, trying to 'smash' it off will jigger the column, but I guess you could try and cut the ally in situ with an angle grinder ,bu t it will make a heck of a mess of the interior.
a working steering lock is now part of the MoT as weel . . .. .
you need to get the plastic cowl off first and there are two screws hidden behind the steering wheel, only visible (just) when steering wheel is at 3 or 9
or remove the steering wheel BUT take EXTRA care cos it's got an air-bag, so battery off for TEN minutes before you start.
there is maybe a 'how to' remove steering wheel?
The cushion is held on with four allen keys accessed from the dash board side, again you need to move the wheel to get decent access
having CAREFULLY disconnect the orange wire (for air bag) under the dash you can lift out the air bag and set it CAREFULLY aside.
there is a wee screw that looks 'lonely' next to the coiled spring contact for the air bag.
it is place into the spring at 12 o'clock and ONLY then remove the screws holding it in place, this lets you get at the steering wheel nut.
all this just to access the two self tappers . .. .
then get at the steering lock
