hand-brake warning light 1993
Post by Alan 480 » Mon Aug 26, 2019 6:49 pm
lazy question.
ignition on and the 'brake warning' light comes on until engine is running.
is it 12V supply at the spade connector?
the handbrake warning light is not coming on regardless of hand-brake lever up or down. tried cleaning the connection where it 'pokes through' the metal frame, no help.
I think the metal strip looks as if it is insulated from frame and just makes contact when lever is down, is this correct? and of course the wire for this is buried below the SRS unit so difficult to remove and replace or even see the colours :-(
SWAMBO assures me that the light was on 'all the time' this AM but OK in PM :?
it does say about a 'fluid level switch' , but I've never seen it, unless that is the wee wire that is fitted into front of servo?
Murf
Re: hand-brake warning light 1993
Post by Murf » Mon Aug 26, 2019 10:15 pm
Does this light not also cover the brake fluid level sensor in the brake fluid tank?
I unplugged mine to change the fluid and it lit the ABS and brake warning light beside it. Mine is a '92 though...
Kia Pro'ceed GT 1.6 Turbo
1992 480 Turbo
2007 Focus ST
Post by Alan 480 » Wed Aug 28, 2019 11:49 am
changed over with different model years, only a SINGLE light
I don't see a level sensor on side of tank, but maybe cos looking on top of tank which is where the SS1 level sensor is :-)
Post by dcwalker » Thu Aug 29, 2019 8:13 am
Slightly confused from your original post as to what the light is doing
- first you seem to suggest it is coming on when you start and going off once engine is running (which is normal in terms of brake fluid check but it should stay on if the handbrake is on);
- then handbrake light not coming on (which accords with light going off when engine running);
- then SWAMBO saying it has been ON all the time.
If these three are all correct that's a bit random!
Yes, there is a fluid level sensor, it is right down the side of the reservoir not at the lid like most are (typical 480 - why keep it simple when it can be made complicated?). Handbrake switch makes contact to turn light off provided fluid level is ok.
If the behaviour is as random as it sounds, I reckon the fluid level sensor is dying.
Post by Alan 480 » Thu Aug 29, 2019 11:43 am
I did see that lead on the servo and thought 'that can't be the level sensor! '
I couldn't remember if the light should go on/off with engine started (and obviously stay on if handbrake lever is up)
but rather than remove the central box/arm rest cubby and fire up the other one just if anybody knew 'off hand' the answer
at present the light NEVER comes on with handbrake on if engine is running
It's not a massive issue as keep an eye on fluid levels and usually remember to put the handbrake off :wink:
further update today, looks as if it it might be the connector into dash board as it was flakey today as I drove to work, rev counter was also dropping out.
really time I got the 'alternative' dash fixed & fitted . .. . .
