Battery Charging
yorkievolvo
Battery Charging
Post by yorkievolvo » Wed Jan 16, 2019 8:27 pm
The charging gauge in the dash of my 480 registers in, or very near to, the red sector, all the time the engine is running.
This is, I believe, not how it should be.
Can't find any info in the forum so it's a case of 'please, has anybody got any info/ideas?'.
Many thanks.
Robou
Re: Battery Charging
Post by Robou » Wed Jan 16, 2019 10:55 pm
The gauge is all but an exact indicator. Check the voltage which a multimeter over the battery, lights, fans and AC off. If it is well over 14 Volts exchange the regulator in the alternator.
Too old to bother
480 Turbo midst '91
Post by jifflemon » Thu Jan 17, 2019 3:32 pm
A multimeter across the battery is the best check - You should see at least 13.5v with the engine running.
However, before starting, check that the battery warning light is lit up on the dashboard with the ignition on, if it's not, it can prevent the alternator from starting to charge. It could be a simple failed bulb, it could also be signs of a dead alternator.
Post by Alan 480 » Fri Jan 18, 2019 12:44 pm
or even the small thin wire broken at the alternator, guess how I know :wink:
yorkievolvo
Post by yorkievolvo » Sun Jan 20, 2019 2:12 pm
Thanks for the info, gentlemen.
Will check the system tomorrow - snooker to-day.
Alan 480 - I believe the expression is "I was that soldier".
yorkievolvo
Post by yorkievolvo » Tue Jan 29, 2019 9:16 pm
Update.
Found single-wire connector wasn't (connected).
Using all my knowledge of electrical circuits; I re-connected it and all is now good.
However, I think I need a new battery.
Thanks for all the info.
Post by jifflemon » Wed Jan 30, 2019 2:17 pm
How old is the battery? How often is the car used and what sort of journeys do you do?
Alternators are not exactly efficient at charging - they're primarily used to run the electronics and keep the battery topped up.
This means if you've a battery that hasn't been being charged for some time, you've possibly taken out more than you've put in.
Especially if you're only doing short journeys (which, in winter time, mean with additional electrical load from Heated seats, heated windows, lights etc).
Sticking it on a good battery charger overnight wouldn't do it any harm.
yorkievolvo
Post by yorkievolvo » Wed Jan 30, 2019 7:21 pm
jifflemon,
three good questions.
How old is the battery? Don't know.
How often is the car used? Every two/three days.
What sort of journeys do I do? No more than ten (10) miles.
I'll just keep removing/charging/re-fitting after & before every trip.
yorkievolvo
Post by yorkievolvo » Mon Feb 17, 2020 10:08 am
Update
Went Lidling yesterday and car wouldn't start after leaving Lidl. Flattened the battery so called out the RAC.
The engineer did his checks and showed me that the alternator was only pushing out 11.6 volts.
So now I'm looking for a new/recond. alternator.
Anybody any ideas/recommendations/spare?
In advance, Thanks.
Post by jamescarruthers » Mon Feb 17, 2020 12:34 pm
I sent mine for remanufacture at Just Alternators and Starter Motors. This is all Mike does and he is surprisingly passionate about what he does.
www.jasm.co.uk
Last edited by jamescarruthers on Mon Feb 17, 2020 3:42 pm, edited 2 times in total.
Post by jifflemon » Mon Feb 17, 2020 3:22 pm
Update
In advance, Thanks.
Just before running for an alternator, have you checked (or did the rac man check) it actually is a alternator problem?
Remember this post?
yorkievolvo
Post by yorkievolvo » Mon Feb 17, 2020 8:56 pm
Thanks James.
I've booked an appointment, for tomorrow morning, with a local reconditioner.
If he's too expensive, I could be sending a parcel to Southampton.
yorkievolvo
Post by yorkievolvo » Mon Feb 17, 2020 9:08 pm
Thanks jifflemon,
the RAC chap connected a couple of black boxes to the car and spent a few minutes letting everything warm up & settle down.
He showed me the readings - 11.6 for the alternator output - was good enough for me.
No point it messing about, I thought, find a replacement.
Change things I can do; when it's a nuts & bolts job.
It's the electrickery bits where I'm stumped.
