Relay Wehrle 20210032 replacement
andyb2000
Post by andyb2000 » Tue Nov 13, 2018 3:24 pm
Hi all,
Anyone know of a replacement for this relay? It's on my 1994 480ES under the dashboard (two side by side). The pin-out seems a little unusual so I'm struggling to find an alternative to order, so any suggestions pls?
Thanks!
WRDendy
Re: Relay Wehrle 20210032 replacement
Post by WRDendy » Tue Nov 13, 2018 3:57 pm
I presume it's not working? If so then can you take pictures of the guts? Might be fixable.
Other than that, plenty on eBay it seems and common to the rest of the 400 series as well:
https://www.ebay.co.uk/sch/i.html?_from ... 2&_sacat=0
Formerly known as 'Jaster'
Current: '94 GT & '88 ES
Former: '89 ES
arthuy
Post by arthuy » Tue Nov 13, 2018 7:07 pm
This may be help, looks like a type A relay to me.
arthuy wrote:
Thu Jun 22, 2017 12:59 pm
This diagram is the five pin version showing the difference between the relay pins, but the 4 pins are the same without the centre pin (87a).
Just in case anyone stumbles across this post with the same issue the part numbers for the correct 4 pin relays are below.
Volvo: PN 472210/01
Pearl: PR06
Bosch: 0 332 019 451 / 0 332 014 406
BMW: 61311354393
Halfords: HEF555
siemens: V23134-K52-X249
Ortovox77
Post by Ortovox77 » Wed Nov 14, 2018 9:41 pm
Closest I could find is the Wehrle 20 210 100A, same pin configuration and 12v 30A.
I cannot find any info on the current for 20 210 032 but I cannot think of anything that should take more than 30A.
Volvo 480 Turbo 1994
Volvo 480 ES/GT 1995
Volvo 480 Turbo 1988
Volvo 480 Turbo 1990 (will be scrapped)
BMW Z4 coupe (ESS supercharged)
Saab 9-5 2006
Rotax DD2 Gokart
arthuy
Post by arthuy » Sat Nov 17, 2018 4:59 pm
Did you get a relay sorted?
You can get them at halfords as per the part number given HEF555 4 pin Type A relay.
https://www.halfords.com/workshop-tools ... -40a-4-pin
Worth buying an extra one.
andyb2000
Post by andyb2000 » Mon Nov 19, 2018 3:28 pm
Ah excellent, thank you so much that looks good! I mustn't have googled enough to find the equivalent/something close!
Thanks again.
