Won't start
Won't start
Hoping for some helpMy '92 480 had been left for some time. When I recently purchased it the indicators didn't work or the ignition key wouldn't turn the engine. Led was constant and no central locking. Replaced CEM now that all works and led flashes goes off when doors are open. Turn ignition engine turns over but pump doesn't run. Now where I am at: Replaced ecu no difference the 2 relays for ignition and pump click when key is turned but took covers off and the contacts close but immediately open again. The coil connections have 12v on both sides ecu has 2 earth connections. Pump runs if I close the relay. Close both relays but still won't start seems like no spark as the engine just spins.
Re: Won't start
On some 480's the pump doesn't run until it detects a pulse from the crank sensor.
Look at that sensor first. Then tell us what engine you have (1.7 in '92). The MAP sensor (cheap and easy to change) was what stopped my project car starting at first.
Re: Won't start
Forgot to mention it's a 1.7 basic no abs or airbag.
I can't get to look at it till Monday now, I think the resistance reading should be around 200ohms is that correct?
Re: Won't start
I'm sorry I don't know off the top of my head.
I think you should see the rev counter needle move a tiny bit as you crank the car if the sensor is working. However, this thinking took me down the wrong route because it turned out my rev counter was actually broken! So bear that in mind.
Re: Won't start
confirm that you do/don't have a spark coming FROM the HT unit !! I've seen teh rotor arm failijw101 wrote: ↑Fri Oct 05, 2018 8:22 amHoping for some helpMy '92 480 had been left for some time. When I recently purchased it the indicators didn't work or the ignition key wouldn't turn the engine. Led was constant and no central locking. Replaced CEM now that all works and led flashes goes off when doors are open. Turn ignition engine turns over but pump doesn't run. Now where I am at: Replaced ecu no difference the 2 relays for ignition and pump click when key is turned but took covers off and the contacts close but immediately open again. The coil connections have 12v on both sides ecu has 2 earth connections. Pump runs if I close the relay. Close both relays but still won't start seems like no spark as the engine just spins.
I had a dicky connection next to flywheel which would prevent starting, pulled apart, cleaned and re-made
Re: Won't start
Glad to see you got your forum access sorted - welcome !! Hope you get your car fixed soon. Perhaps we will see you both at a meeting next year. Watch out for the May mobile meet Northampton to Derbyshire.
Re: Won't start
Yes thank you for your help.
Re: Won't start
Well today I started my 480 and was pleased with the sound of the engine even though I have no back box.
The problem of no fuel pump relay switching, was the crank sensor, I then had no spark but that was the previous owner not connecting the coil pack correctly causing me a little bit of head scratching. Now for the rest of the jobs. Thanks for the help guys.
Re: Won't start
Excellent news, well done
Re: Won't start
well at least it would have been a 'cheap' fixijw101 wrote: ↑Wed Oct 17, 2018 1:14 pmWell today I started my 480 and was pleased with the sound of the engine even though I have no back box.
a running car is always worth keeping going, if it is not running it puts dampner on things
Re: Won't start
Next thing guys what temperature should the fan kick in I was scared and turned off at 94degrees the electric water pump continued to run
Re: Won't start
mine used to kick in around high 80s / low 90s but don't have a leccy water pump. (93 two litre)
check the fan runs when you supply it with 12V, could be the switch or the fuse, or just STUCK (really cheap fix if you can get it to turn), my switch packed up years ago so fitted a 'Kenlowe' style one as it was sitting on the shelf form another car and even when swapped radiator I didn't fit a new switch (daft but was pleased to get a NOS radiator for buttons)
comes on now around mid 80s
Re: Won't start
The fan won't kick in until much later, and that is fine. On my old B18E (different to yours) the fan kicks in at about 105 deg. C.
The electric auxiliary water pump is a different matter, that is triggered to come on at a lower temperature when the ignition is off to avoid hot spots in the engine.
Sorry, I am away and don't have my books to tell you the figures. But your car sounds like it is looking after its temperatures well
Re: Won't start
That's great thanks
Re: Won't start
Would be good to check if the fan will kick in though!
Re: Won't start
you mean 'will it run if I supply 12V?'jamescarruthers wrote: ↑Wed Oct 17, 2018 8:28 pmWould be good to check if the fan will kick in though!
according to HBOL
ON 95 slow speed, 101 high speed
OFF 90 96
if it has the two stage switch, ie three wires (maybe mine did, can't remember )
Re: Won't start
Hmmmm, I wonder if I am missing the low stage or whether the earlier cars are different?
Re: Won't start
According to the Green Books the two speed fan was for cars with Air Con.
Book doesent give off temps but both turn on at "above 92C" and cars with A/C have second speed at "above 98C".
480 ES Auto 1989
480 Celebration 187
480 ES Auto 1991
CLK430 Conv 2001
Hyundai i10 2015
480 ES Auto 1989
480 Celebration 187
480 ES Auto 1991
CLK430 Conv 2001
Hyundai i10 2015
Re: Won't start
Mine has three wires to the radiator switch.
I don't have a back box for the exhaust so am not inclined to run it yet, but once I get the exhaust done I will look more into it.
