Immobiliser & central locking problems - unable to start car
Posted: Sun May 20, 2018 5:29 pm
by 89of480
So I got the car all MOT’d yesterday and everything (more on this later), but since yesterday (despite nothing changing) I’ve been having issues with the immobiliser not working, or rather working, and leaving me unable to start the car. There seems to be an intermittent problem with the driver’s door lock, when turning it with the key, it doesn’t actually power open; it just unlocks and therefore does not power open the passenger door, the LED will either remain solid on, or will flash until I put the key in the ignition and then go solid on, leaving me unable to start the car. Sometimes the driver’s door will power open and open the passenger door, other times the passenger door will power open after opening the driver’s door. I ended up getting stranded at a petrol garage right before my MOT and had to wait for my dad to come to the rescue with a spanner to disconnect the battery! I found a couple of bolts loose in the side of the door that hold the latch in place, I tightened these up and a couple of times after this the doors powered open fine, I thought this had solved the issue but now I’m still having troubles with it, completely out of nowhere. Can anyone help point me in the right direction for this? Thanks
Re: Immobiliser & central locking problems - unable to start car
Posted: Thu May 31, 2018 11:48 pm
by 89of480
Sorry to ‘bump’ this again guys, but my mind has been stirring away here, is it possible the driver’s door solenoid/unit could be the culprit here? It would mean a lot to me if someone could help me out with this
I dont want to end up stranded somewhere!
Thanks guys! You’re the best!
Posted: Fri Jun 01, 2018 8:55 am
by AleksanderHugo
I would start by getting to the microswitches by the lock. Remove the plastic cover of the lock on inside of he car and see if all the meachnical parts are in place. When you turn the key a plastic “ring” presses a microswitch which sends a signal to the CEM.
If mechanical parts are ok, then check the microswitch itself, then wiring and then the CEM.
Posted: Fri Jun 01, 2018 11:34 am
by Alan 480
AleksanderHugo wrote: ↑Fri Jun 01, 2018 8:55 am
sounds like a decent suggestion, I had a similar issue (in reverse) after working at the boot lock, alarm went off when closed the boot !!
switch was in 'wrong postion'
so could well be the issue
Posted: Fri Jun 01, 2018 12:48 pm
by 89of480
Excellent!
thanks for pointing me in the right direction, I shall report back once I’ve had a chance to look!
Alan 480 wrote: ↑Fri Jun 01, 2018 11:34 am
I’ve yet to hear the alarm go off! Do you need a fob for the alarm to operate though?
Thanks for your input though, I shall indeed have a nose soon!
Aah, 480 electronics...
Posted: Sun Jun 03, 2018 8:26 pm
by 89of480
I’ve posted a couple of videos on YouTube to try and show what’s going on, just to recap;
•as of now, the passenger door (good one) will power open and disable the immobilser and turn the interior lights and let the car start
•it will also close the windows, arm the immobiliser and turn off the interior lights
•the passenger door will not lock or unlock the driver’s door (dodgy one) though
•the driver’s door will unlock, but not power open, turn on the lights or disable the immobiliser
•sometimes opening the driver’s door will unlock the passenger door (but still not disable the immobiliser)
•the driver’s door will lock the passenger door and close the windows (and arm the immobiliser and turn off the interior lights)
Anyway, here are the video links, in case they are useful? Thanks!
https://youtu.be/5cIFcPXmfe4
https://youtu.be/ezTJvrknO5w
Posted: Mon Jun 04, 2018 11:39 am
by Alan 480
for what it's worth,
the passenger door lock will NOT unlock the driver's door on ours. there is ONLY a solenoid on the passenger door!
it does all point to an issue around the switch on the door lock, or the relay within the central module?
Posted: Mon Jun 04, 2018 12:44 pm
Are you sure that you actually have an immobiliser?
Posted: Mon Jun 04, 2018 1:42 pm
by 89of480
jamescarruthers wrote: ↑Mon Jun 04, 2018 12:44 pm
I am sure, if I unlock the driver’s door at the moment the LED keeps blinking and then goes solid when I turn the ignition key, and then the engine doesn’t start, but if I unlock the passenger door the LED goes out and I can start the engine fine; locking the car also makes the LED start blinking.
After the state I found the car in I’m surprised the immobiliser still works!
Alan 480 wrote: ↑Mon Jun 04, 2018 11:39 am
Thanks for the insight - I couldn’t remember how it was before to be fair, but that’s genuinely useful to know, thank you!
It does indeed, I shall see if I can pop the door card off later and see if I can get to the locking parts, I’ll see if I can check the switches and cover some of the connectors with some contact cleaner and go from there
Posted: Mon Jun 04, 2018 10:43 pm
by 89of480
Thought I would add an update; I removed the door card and the plastic lock cover, and I used a generous amount of contact cleaner on each connector inside the door, I tried to spray some towards their direction of the micro switches along with some silicone spray for some of the mechanicals, and so far so good! The drivers door is functioning correctly again! I just hope this fix holds out!!!
Posted: Tue Jun 05, 2018 11:54 am
by Alan 480
89of480 wrote: ↑Mon Jun 04, 2018 10:43 pm
my type of fix
Posted: Wed Jun 06, 2018 11:48 am
by 89of480
Alan 480 wrote: ↑Tue Jun 05, 2018 11:54 am
my type of fix
Thanks!! I will have another to later just to make sure it’s still okay!
Posted: Wed Jun 06, 2018 11:13 pm
by 89of480
Unfortunately my fix was only temporary as I tried again today and no joy whatsoever
At least I can disable the immobiliser with the passenger door...
Posted: Wed Jun 20, 2018 11:55 am
by Alan 480
so 'central-locking' but not 'central-unlocking'
the old Regal also had central locking, you could reach both doors whilst seated
Posted: Fri Nov 23, 2018 2:39 pm
by nigeltowner99
89of480 wrote: ↑Sun Jun 03, 2018 8:26 pm
Just to say that neither of the youtube links appear to work -
