what should be lit
frenchfries
what should be lit
Post by frenchfries » Sat Jul 08, 2017 5:12 pm
Hi all
I have finally tried the inside lights and a few are not working:
I know that the bulb in the rotary switch has blown, is it why this cluster is dark?
InfoCentre is dark and there is not light on the Warning switch. Also, the little white knob that regulates the temperature is dark as well.
Any suggestion welcomed :)
Moi
arthuy
Re: what should be lit
Post by arthuy » Sat Jul 08, 2017 5:48 pm
The bulb for the rotary switch lights up the switches.
I replaced mine, the switches on mine are bright but the switch is still dim.
Post by Alan 480 » Sat Jul 08, 2017 8:43 pm
I've less worried about the bulbs, more on the function and dash board remaining in one piece, mostly held by the vinyl! :-)
I just remember the top is screen and bottom is 'rear' fog lights so the middle must be front fogs :wink:
the hazard should also be lit, mine was dark for about ten years then suddenly burst into life (without any input from me :-) ), in reality it's too bright
the info centre switch has never lit up on ours, and when I had one apart I don't think there was a bulb . .. .
frenchfries
Post by frenchfries » Sat Jul 08, 2017 9:39 pm
So
1.2W T5 for the rotary switch and ideally 0.36W for the Warning light.
Step by step :)
I would like everything to work as it should :roll:
