Battery drain
Re: Battery drain
Just checked, you can actually see the whole picture if you click on that.
O.C. 480 D.
Re: Battery drain
I can see it, thank you so much, that helps loads.
Re: Battery drain
Any update? How many amps/milli-amps are you pulling?
Re: Battery drain
One other thing to rule out - and which was draining my battery overnight until i figured it out - is wear in the brake pedal mechanism which causes the pedal to drop slightly, activating the brake light switch. I had no idea what was going in with my car until one day I glanced back at it after parking to see my brake lights come on of their own accord.
Best way to check this is to lightly press your brake pedal with your hand whilst someone watches the lights at the back of the car. If the lights come on with almost no pedal movement (and if there appears to be some play in the pedal) this could be the answer. It's an easy fix too, you just sit upside down in the driver's seat with your head under the pedals and adjust the brake light switch. If I remember correctly it's a little white push switch which can be turned anti-clockwise to extend the part of the switch which makes contact with the brake pedal when it is not depressed and therefore keeps the brake lights off.
Bit of a long-shot perhaps, but worth ruling out. Tormented me for months!
1992 Paris Blue 480 ES
Re: Battery drain
thanks for that. I will check but pretty sure my brakes lights don't come on when parked up, well worth check thoughnicklee wrote:One other thing to rule out - and which was draining my battery overnight until i figured it out - is wear in the brake pedal mechanism which causes the pedal to drop slightly, activating the brake light switch. I had no idea what was going in with my car until one day I glanced back at it after parking to see my brake lights come on of their own accord.
Re: Battery drain
Alas, no update. The return of my beloved 480 has been hampered by very slow sorting of the garage. I need to empty the garage which has become a dumping ground of builders 'stuff' and seal and paint the floor before she comes home from here holiday in Oxford. I am hoping this will be done in the next few weeks, and then I can get to work in finding the problem. Any news and I will report straight back.jifflemon wrote:Any update? How many amps/milli-amps are you pulling?
Thank you
