OMG! Another info centre thread
smutsa332
Post by smutsa332 » Fri Jul 31, 2015 1:25 am
Sorry about this but I have been through all 33 pages and can't find this issue.
My info centre on my 93 480 ES constantly shows inst MPG. Turning the switch makes no difference to the display.
When I am running low on petrol it automatically changes over to range, but returns to inst mpg after
When I start start it up it flicks over and does all its checks etc but returns to inst mpg.
Any ideas or am I just better living with it in case I make things worse?
Thanks in advance
eye of ra
Re: OMG! Another info centre thread
Post by eye of ra » Fri Jul 31, 2015 7:16 am
Check to see if the connector on the back of the switch has become detached.
480 ES Auto 1989
480 ES Auto 1991
CLK430 Conv 2001
Hyundai i10 2015
Swanny
Post by Swanny » Fri Jul 31, 2015 9:03 am
Yeah this must be the switch or connector, all the functions you mentioned are automatic and not controlled by the switch. I pulled mine out this week and the connector is quite flimsy (shock!)
smutsa332
Post by smutsa332 » Sat Aug 01, 2015 12:38 am
thanks for the replies.
How is the switch removed?
(This is the answer I'm dreading) I really am a bit useless at this kind of stuff.
doingitsideways
Post by doingitsideways » Sat Aug 01, 2015 8:14 am
It's just a push fit into the dash.
Bit of leverage with a scraper or similar and it's out. :)
Hammers can't fix a 480!!!
smutsa332
Post by smutsa332 » Sat Aug 01, 2015 6:05 pm
thank you
