info centre
info centre
Hi the info centre circuit board has a different no on the vdo chip and does anyone know the difference between chips and its affects if that makes any sense whatsoever 'thanks
Re: info centre
what is the chip number you need for a like for like replacement?
Re: info centre
Hi jim the chip no is 582 and I have a spare but capacitors look rather suspect and have replaced capacitors on my origins board but yet to try 'problem I'm having is no coolant temp on ic and same with fuel gauge 'have checked fuel pump resistance and all fine as with sensor on head ,going to replace a few connectors in engine bay some of the pins look a little green ,any input would be great 'thanks
Re: info centre
HI POE info on the different info center chips/boards:
http://www.volvo-480-europe.org/volvo48 ... ment_panel
Hope it helps
Hope it helps
Re: info centre
Hi thanks for info and seems chip is used for different tank and fuel pump variations maybe ?
