speedo cogwheel Joep fix...
timrosser
Post by timrosser » Fri Mar 20, 2015 5:03 pm
HI everyone, I have just got my Joep cogwheel to try and fix my speedo- I have a set of instructions in Dutch, any links for an English how too?
Best
Tim
Robou
Re: speedo cogwheel Joep fix...
Post by Robou » Fri Mar 20, 2015 9:47 pm
Check this out:
http://www.volvo480forum.com/index.php/ ... 721.0.html
and use Google translate. A personal addition to how to remove the needle: Grap it under the hood and turn it anti-clockwise while lifting. Be brave, it will work.
And when the frontplate is glued remove it with the blade of a Stanley knife. Watch the small notches though, do not cut them.
You will understand this abracadabra when you hold the stuff in your hands.
Too old to bother
480 Turbo midst '91
timrosser
Post by timrosser » Sat Mar 21, 2015 12:16 am
Thanks Robou, may well be on here in a week asking for new instruments instruments, but thanks for the advice and pep talk :-)
Van
Post by Van » Sat Mar 21, 2015 7:24 pm
Some weird errors in that Dutch. If you need help with a line post it here and I or another helpful member will help translate it.
Dancing Demon
Post by Dancing Demon » Mon Mar 30, 2015 5:56 pm
I too have just got mine.
Looked everywhere to find a business that would do it - but couldn't had to do it myself!
The pics are fantastic and I had no problems (apart from one) changing the cog and it works - MANY THANKS to Joep for being able to supply it.
HOWEVER a word of caution which gave me an issue and may not have done had a read the instructions. When removing the needle for the speedo make sure the force is on the actual needle where is connects around the bit which goes on the spindle - the fork is a great idea but make sure you fully put the fork under so the force is ver localised. I DIDN'T and havbe had to glue the fixing back in my needle.
Just put it back and all works well apart from info centre which has now stopped. (was working fine before)
It also helps having the right tools......... (hex keys, small screwdrivers)
Chris
Dancing Demon
Post by Dancing Demon » Mon Mar 30, 2015 5:58 pm
I would very much like to publish the article in the Volvo Owners Club magazine.
Is someone able to communicate with the author and ask his permission? (Sorry I can't write/speak Dutch!)
It would also be great if they could email me the original pics.
Chris
timrosser
Post by timrosser » Mon Jun 15, 2015 4:17 pm
Any tips on the size of alan key needed to unscrew the screws on the rear of the instrument pod?
hebruins
Re: speedo cogwheel fix...
Post by hebruins » Mon Jun 15, 2015 5:53 pm
There's no alan key needed. It's either a phillips screwdriver of a Torx T10 you need.
For those that will repair their speedometers themselves: NEVER USE A FORK!!! That will break the needle.
And for those in need of a cogwheel: check out http://www.volvo480forum.com or their Facebook page: They sell them for €13,50.
Volvo 480 GT-Turbo 1995 ~ 321 current
Volvo 480 Turbo 1994 ~ 305 got totalled
Volvo 480 GT-Turbo 1994 ~ 323 sold
Volvo 480 Turbo 1993 ~ 305 sold
